When using my fluid pump, I barely get enough pressure to reach the glass. I've looked on YT but can't find a good video on where the pump is located. Does anyone have any experience with replacing the fluid pump on a 2020?
This image will show you where the pump is located. I will assume you need to remove or loosen the driver side fender liner to gain access to the pump. Before you go poking into the nozzles with a piece of wire....disconnect the hose going to the nozzles and see if the pump delivers.
Thank you for the visual graphic! So after removing the fender liner, I should be able to access this from above the tire, or remove it all, and then I'll be able to access the pump.
