Fuel Tank Drain
Old Oct 27, 2025 | 05:09 AM
BobcatNT's Avatar
BobcatNT
Fuel Tank Drain
I need to drain the front tank on my gas burner 97 F350. Fuel pumps froze in one storm and ruined both pumps. I was unable to drop tanks so I siphoned them and put in new pumps. Was unable to get complete front pump assembly so used old top and just replaced pump. I guess check valve is bad so back pump fills the front tank. It is full of bad gas and sputtering on front tank. I want to drill a hole, drain tank and plug with a metal roofing screw. Have done this with diesel tanks but afraid of spark catching fire with electric or cordless drill. Brace and bit maybe? Can’t really abandon front tank as I need to swap to it to use transferred gas from rear tank. Correct pump was not available. I ordered 5 to get that one and Ford dealership said it could have had 1 of 12 possible pumps.
gmd25m
Sep 19, 2022 12:35 PM
Rm604
6.4L Power Stroke Diesel
Jan 3, 2022 06:49 PM
ah1988
16
Feb 14, 2020 03:42 PM
Karstonian
Aug 28, 2004 08:44 PM
moose94
Apr 10, 2004 10:43 PM
