No speedometer
Old Oct 25, 2025 | 12:09 AM
that94xlt's Avatar
that94xlt
Trailering
No speedometer
On my 94 f150 with a 5.0 the speedometer doesn’t work. I’ve tried checking wiring, checked the transmission sensor, can’t get the rear axle sensor out to check it, but my odometer still works and fuse 18 is still good. What do I check now other than finding a way to get the rear sensor out. It’s also shifting lazy and it doesn’t want to shift back into 1st when I stop after shifting into 2nd. Any help would be appreciated
Old Oct 25, 2025 | 12:12 AM
wwhite's Avatar
wwhite
Old Oct 25, 2025 | 05:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
if the odometer i working the axle VSS is working. my bet is the speedometer head or PSOM is bad.
Old Oct 26, 2025 | 09:23 AM
manicmechanic007's Avatar
manicmechanic007
The ABS gets that signal first, followed by the cluster then followed by the processor IIRR
With a EVTM you should be able to trace down the splices and connectors in question
Agree, the signal is most likely there and you need a speedo
I'd pull the cluster out and check for the pulsating (AC milli) voltage from the VSS and replace the speedo after some testing
Old Nov 3, 2025 | 08:26 AM
that94xlt's Avatar
that94xlt
Trailering
ended up changing the vss on the diff and got the speedometer to work, but its bouncing around. its fairly stable (but bounces some) up to 30-35 mph then after that it just goes haywire. also I just realized that before I replaced the vss the odometer was showing the miles, but it wasn't recording them
Dduke.5383
Dec 30, 2023 08:25 AM
Gsd129
Oct 25, 2023 12:41 PM
hansosc
May 31, 2008 02:24 AM
redneck4242002
Oct 11, 2005 07:46 PM
Jeepincj7
1978 - 1996 Big Bronco
Jul 2, 2003 06:17 PM
