1978 - 1996 Big Bronco
Help! Speed sensor prob?
Old May 11, 2003 | 03:22 PM
Jeepincj7's Avatar
Jeepincj7
Well, I just started having fits with my 94' 5.8L. The speedo and odometer stopped working. At the same time the transmission doesn't want to shift at normal RPMs. It requires me to nearly hit 4000rpms before it will shift into 2nd and 3rd. The shifts are hard and abrupt as well. I assume that this is sensor related, but I am not getting a check engine light.
Any ideas?
Old May 11, 2003 | 09:05 PM
bigric's Avatar
bigric
Check this thread out:
https://www.ford-trucks.com/forums/s...hreadid=112702
It's probably either your vehicle speed sensor, your speedo head is bad, or the fuse under the hood is bad.
Old Jul 1, 2003 | 06:40 PM
94kicker's Avatar
94kicker
Question Help! Speed sensor prob?
I have a 94' 5.8L with the same problem. What was the fix for you?
Old Jul 1, 2003 | 06:49 PM
nakbe's Avatar
nakbe
Thumbs up Help! Speed sensor prob?
Hey bud,
You are in luck, I happen to own the same year and engine Bronco, and on top of that I had the same problem; the good news is that I fix it my self for only twenty bucks. All you got to do is go to the dealer and ask for the rear wheel or axle antilock brake speed sensor, this sensor is located on top of the housing in the middle of the rear axle; is hold in place by one bolt. change it and hit the road ( or off-road)...
Old Jul 1, 2003 | 10:15 PM
bigric's Avatar
bigric
If the fuse is intact and the speed sensor doesn't fix it, then get a junkyard cluster and use the speedo head from it.
Old Jul 1, 2003 | 11:11 PM
94kicker's Avatar
94kicker
$23 speed sensor from Kragen Auto and it seem to be running better then ever. ABS light went out right away , speedometer working, never shifted so smoothly. Do these sensors degrade over time or do they either work or don't?
Thanks
Old Jul 2, 2003 | 06:17 PM
steve83's Avatar
steve83
They collect metal shavings from the oil in the diff because they're magnetic, and over time, they can develop a strong enough field that they don't work right. It happens slowly.
nicke147
Jul 25, 2015 05:17 PM
96_Powerstroke
Dec 22, 2014 09:03 AM
nicke147
Jan 19, 2012 11:17 AM
Buckin_Bronco
Aug 6, 2010 07:08 PM
captjohn
Oct 31, 2004 06:58 AM
