Engine bay noise
Old Oct 23, 2025 | 09:30 AM
1978 F150 Nik's Avatar
1978 F150 Nik
Trailering
Engine bay noise
Hello,
Not huge mechanically inclined but learning more each time. Over the past week or so, I’ve noticed a chirping/ squeaking like sound. It appears to get louder/ more prevalent at idle vs driving. I changed the oil yesterday and that did nothing. The belts themselves appear fine. From what I read, they aren’t torn/shiny/damaged.
Old Oct 23, 2025 | 09:38 AM
tbear853's Avatar
tbear853
Belts will do it as will a alternator or other bearing. Next time it does it, try spraying the belt with belt dressing. It comes in a spray bottle from most any auto parts store or Walmart, etc. Just spray the belt as it idles, watch out for moving parts. Doesn't take much.
Old Oct 23, 2025 | 09:44 AM
beartracks's Avatar
beartracks
I would use water instead. I have seen belt dressing cause the belts to grap and make a sound very much like a rod knock. Wasted a lot of time chasing the sound once untill I remembered using the dressing.
If you have AC it could be the idler pulley.
Old Oct 23, 2025 | 09:53 AM
1978 F150 Nik
Trailering
ordered. I’ll give it a shot
Old Oct 23, 2025 | 09:54 AM
1978 F150 Nik
Trailering
I’ll try water as well. Thank you
1978 F150 Nik
Trailering
And if it is not the belt. What’s something I should look at next?
Old Oct 23, 2025 | 10:17 AM
tbear853's Avatar
tbear853
A bearing. I use a old night stick, it is hickory, but you have to be focused on not letting it get in the fan or a pulley, no distractions .... hold one end against an ear and touch things like water pump, alternator, ps pump housing, etc. A stethoscope also works to isolate the source.
I've seen big screw drivers used, but I also saw one thrown plumb across a shop.
Old Oct 23, 2025 | 10:46 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 what ever you do, BE CAREFUL when working with the truck running. The fan blade, belts, moving alternator parts, p/s pump pulley ect are not kind to fingers....Do you have a fan shroud? If not BE EXTRA CAREFUL. Check the p/s fluid, do the belt dressing or water trick and check belt tention (when the truck is shut off). Flat edge on top of pullys, measure the belt flex down amount.
Do not alwasy stand in front of the truck to try and find the noise, try standing on one side of the truck engine bay and then try the other side. Have some one else do the throttle blip bump to get the sound to come and go. Yes a simple 1/2 or 1/2" wooden dowl rod works, same for the eng stethoscope.
Also have them apply some steering changes to it, at idle and at a little bit above idle.
https://www.harborfreight.com/mechan...ope-63691.html
Old Oct 27, 2025 | 10:19 PM
1978 F150 Nik
Trailering
Fixed
It was the belt. Hit the bottom of the belt that makes contact with the pulley using the spray. Went away instantly. Doesn’t sound like it’s gonna blow up anymore lol
ghostpow
2015 - 2020 F150
Feb 20, 2021 11:06 AM
Grout-Scout
6.7L Power Stroke Diesel
Mar 23, 2015 06:12 PM
kper05
Sep 11, 2010 10:55 PM
Matt Wilson
Apr 12, 2005 07:22 PM
mikeil888
Sep 27, 2002 01:28 PM
