Modular V10 (6.8l)
Power Steering Leak Question
Old Oct 22, 2025 | 11:28 PM
yknotgo's Avatar
yknotgo
Hey all,
I recently moved our Excursion that had been sitting at a friend's place for a couple of months with our pop-up attached to it. When I parked at our place, saw a puddle of fluid which I assumed to be from the power steering system somewhere. Checked it out today and confirmed it's coming from the line that threads into the pump, from the treaded part itself. I tried to tighten it with a small crescent wrench (all I had that I cut for in that small area) and it was pretty snug, I got no movement. Any ideas as to what would cause it to leak from the threaded area? I think this end just has a Teflon washer if I recall correctly. I replaced the pump and lines last year while doing a bunch of other work. No known leaking until what I noticed last week, but it's probably only been driven a couple thousand miles, if that since install. I attempted to attach a quick video of the leak.
Thanks for your input.
Grady
File Type: mp4
Old Oct 22, 2025 | 11:31 PM
yknotgo's Avatar
yknotgo
Here is a screenshot from a video in case the video doesn't work.
Old Oct 23, 2025 | 05:12 AM
charlie g's Avatar
charlie g
FTE Community Team
personally i would replace the line , good chance that lines been on and off enough that the connection has flattened to where it no longer seals
Old Oct 23, 2025 | 06:50 AM
yknotgo's Avatar
yknotgo
I may do that as if I recall, it's not too expensive (using one from RockAuto, I think this was an Edleman), but I just installed it last year. New pump, lines, rebuilt steering box.
Old Oct 26, 2025 | 12:45 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
You could try using pipe tape on the threads.
Old Nov 3, 2025 | 05:23 PM
Excurvelle's Avatar
Excurvelle
I just replaced mine, you need an 18MM crows foot, the gasket was leaking.
Bobp67
Mar 11, 2021 05:18 AM
phantomphixer
Jul 17, 2014 12:20 AM
John7894
Aug 16, 2012 07:55 PM
1Saint
Dec 21, 2009 07:39 PM
lionsteve
Mar 29, 2007 05:15 PM
