2010 Backup Sensor Failure
Old Oct 22, 2025 | 02:11 PM
KimWill's Avatar
KimWill
4th Gear
Hello,
My 2010 F150 Lariat back up sensors have failed. Enabling them from the Setup display option does not work. I have listened to each sensor and cannot hear a ticking noise. I'm skeptical they would all stop working at once. I've checked fuse diagram resources and don't find a fuse bank to check for a blown fuse. I'm about ready to take it to a dealer although I dread doing so.
Any suggestions? All are appreciated.
Thank you.
Robert Williams
Flower Mound, Tx
Old Oct 22, 2025 | 02:56 PM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
You will need to scan the truck. It probably has body codes and those generally wont turn on the CEL. There is a whole list of diag steps but they are very specific to a code and symptom not just they don't work. Here are couple wiring diagrams if you want to do some test light probing.
-Dan F
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Old Oct 23, 2025 | 11:23 AM
KimWill's Avatar
KimWill
4th Gear
Thank you! I will pull the scan codes and see what it shows. I appreciate your help.
Old Oct 23, 2025 | 03:36 PM
AppleFordParts
SPONSOR
Not a problem. If you post the codes I can check Ford PTS to see if there's any simple diag procedures you can do.
__________________
Old Oct 25, 2025 | 02:48 PM
KimWill's Avatar
KimWill
4th Gear
I pulled the codes. It returned U0159. My scan tool said it was either a wiring issue or the Parking Assist Control Module needs replacing. I think I will try and replace the parking assist module if I can find it and get to it. I'm not sure what it looks like or where it is located on a 2010 F-150 Lariat.
Old Nov 5, 2025 | 01:59 PM
KimWill's Avatar
KimWill
4th Gear
I pulled the module. It is FoMoCo 9l3t-15t850-ab. It seems it is no longer made. Checking to see if I can find one. They seem to be scarce. I wish I could find a new one from Ford.
Old Nov 6, 2025 | 09:18 AM
nitebreeze's Avatar
nitebreeze
I have read that when parts get updated, they usually change the part number. Check for that module on a newer year F150 and see if it uses a part number that replaces the part number from your truck.
Kernel_Eb_Stuart
2015 - 2020 F150
Apr 25, 2022 12:34 PM
mikeceli
13
Apr 7, 2021 03:24 PM
740steve
Aug 22, 2013 03:24 PM
jmikeyj4
Feb 8, 2011 03:49 PM
kdtupper
Electrical Systems/Wiring
Oct 10, 2008 10:31 AM
