6.2L V8 Discuss the 6.2L V8
Oil question....but not about which is "best".
Old Oct 20, 2025 | 02:10 PM
Qwazert's Avatar
Qwazert
Just did an oil change on my 2012.
I used 5W-30 like I've been doing for the past 30,000 miles...I remember reading a bulletin (somewhere) that although 5W-20 is recommended for the 6.2, it can also be run using 5W-30.
Today I read that this only applies to the "newer" versions of the 6.2...whatever THAT means.
So anyone else with an older 6.2 running 5W-30? Noticed anything to be wary of?
I will usually run the 5w-20 in the winter months, more so for the cold-starts than anything else, and switch to the 5W-30 for the summer when we tow 95% of the time and the ambient temps can get into the high 90's...
Old Oct 20, 2025 | 04:51 PM
2015 F-350's Avatar
2015 F-350
The 5W is the same for both (characterized as "Winter", so no difference for either). Best to go to BITOG and suss out the answer there - but be ready for the "discussion"!
Old Oct 22, 2025 | 03:28 PM
scraprat's Avatar
scraprat
Top Answer: 5
When I had my 2012 F350 6.2. I used MC 5w20 with 7,000 mile oil changes its entire ownership. When it went to the next owner it had 212,000 miles with no issues.
Old Oct 22, 2025 | 08:24 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I changed my 2013 6.2 to 5W-30 few years ago and it eliminated all startup to ticking but the truck is always in the warm weather. I can see no difference when using the 5-30 over 5-20 and will continue using it. Our truck has never used any oil on either oil with 7K between changes.
Denny
Old Oct 23, 2025 | 07:24 PM
fire240's Avatar
fire240
I h e been running 5w30 in mine since I started doing the oil changes myself once my truck was out of warranty. Truck got what ever the dealer used when they changed it.
Old Oct 31, 2025 | 12:01 PM
crashz's Avatar
crashz
I use 5w-30 in my truck but my intervals are pretty short. I do a lot of short trips with occasional heavy towing, so I change it at 3k miles. Seems soon but that's about every 6 months.
Old Nov 1, 2025 | 12:30 PM
Split rims's Avatar
Split rims
5W-30 in my 2013 since Ford made the change.
Since 100,000 miles I've been using Valvoline R&P
with Purolator boss filters.
Courtney Williams
Dec 4, 2019 06:57 PM
mattpowerstroker
May 19, 2007 10:24 PM
durtyburd
Apr 30, 2007 03:34 PM
Muktown
26
Jan 14, 2007 01:10 AM
TommyLee
Oil & Lubrication
Feb 3, 2004 03:54 PM
