V10 Gas engine Ping or ?
Old Oct 19, 2025 | 11:28 AM
Michael Watkins's Avatar
Michael Watkins
5th Gear
On last 800 mile trip I noticed what sounded like engine pinging when climbing modest hills. My question is, “Was it engine pinging or could it be something else? I did not notice any power loss and there were no other issues. It’s a 2017 E450 Super Duty with 24k miles. Has recently had oil and filter changed and using 87 octane gas.
Old Oct 19, 2025 | 05:08 PM
tabijan's Avatar
tabijan
Do you have access to a scanner with live data so you can monitor knock counts? If it were pining to the point you can hear it, it could retard timing and possibly set a fault code. If the sound isn't pinging, there could be a component hitting resonance at higher rpms - loose heat shield, loose bracket, etc. But odd that it only hits resonance under load.
Sixto
07 E350 5.4 200k miles
Old Oct 20, 2025 | 06:11 AM
manicmechanic007's Avatar
manicmechanic007
Lean misfire can also cause a spark knock condition
Stop, turn the vehicle off and let the processor reset the timing back to base a few times during the drive
You should be able to notice the knock getting better and worse while doing that
I'd also check the fuel trims and watch the front O2 sensors switch
If you have one (or both) O2 sensor(s) stuck lean and a failed injector, spark knock will be the result
When my 4.2 did that, using 91 octane had no effect
Old Oct 20, 2025 | 07:24 PM
Michael Watkins
5th Gear
Thank you for the suggestion. I’ll look to see if there are any fault codes.
Patrick4451
2023+ Super Duty
52
Sep 9, 2022 08:32 PM
Hkyplayr2
Jan 28, 2016 07:39 AM
kel1306
Sep 24, 2015 02:22 PM
rescue7
Modular V10 (6.8l)
13
Dec 15, 2005 06:08 AM
V10gunner
Apr 23, 2002 06:41 PM
