Ford 5.x Update
Old Oct 18, 2025 | 10:35 PM
ARKSoft84's Avatar
ARKSoft84
8th Gear
Ford 5.x Update
I obviously have some learning to do. This is my first Sync 4 vehicle. I've been trying to figure out why my cluster keeps reverting back to the "My View" main screen, and in doing so found the TSB associated with it. Figured I could solve it with FDRS, found out that I couldn't. Then found that Ford released a software update back in 23 that should have fixed this, but my truck was on a ranch in Texas, and has only ever had 2 updates, and that wasn't one of them.
I've read that there really isn't a way to initiate an OTA update. Has that changed? Is calling Ford's technical support worth it?
Any advice is greatly appreciated.
Old Oct 20, 2025 | 07:05 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Can't initiate an OTA update, they get pushed out when they get pushed out. I think there's a way to download the update and put it on a USB stick but I've never personally tried it.
Other option is to have it done by a dealership.
Old Oct 20, 2025 | 07:28 AM
Tsax6010's Avatar
Tsax6010
The USB offline method went away with Sync 4
Old Oct 20, 2025 | 09:01 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Updates can be done via FDRS is they are available for your truck based on VIN
ZooDad
Old Oct 20, 2025 | 09:30 AM
ARKSoft84's Avatar
ARKSoft84
8th Gear
ZooDad
Unfortunately I updated every module that had an update in FDRS. The IPC wasn't one of them.
I tried to PMI the IPC to see if it would pull an update and it didn't. I also tried to PMI the APIM no luck their either.
Old Oct 20, 2025 | 11:06 AM
function12's Avatar
function12
My 23 has the same issue. I sure wish I could get it fixed. Dealership had no interest in helping.
Old Oct 20, 2025 | 10:21 PM
7.3TreeFiddy's Avatar
7.3TreeFiddy
My 2023 had this issue as well. I got the dealership to update the IPC after I complained about the direction I was driving not being displayed even though it was referenced in the owners manual. You might try that.
TestPilot57
2023+ Super Duty
26
Sep 22, 2025 10:58 AM
Poncho450
Aug 12, 2024 04:38 PM
canthony24
2015 - 2020 F150
Jul 7, 2021 10:25 AM
Wildweasle86
Dec 8, 2019 09:12 PM
garypettengill
Nov 17, 2002 09:16 PM
