My 2001 f350 was having a little bit of a hard idle. I did a buzz test and two injectors failed. They were on opposite sides. I have a 99 f250 that i stopped driving.I swapped injectors on my 2001 7.3 with injectors off my other truck that had only 6 months of use. I removed and installed them with no error(to my knowledge). When starting the truck it was billowing smoke out the exhaust and under a little pedal it was worse than a coal train. I turned engine off, and went and did some running. After 3 hrs I started it up and no smoke under idle but still thick clouds under pedal. I am clueless to what I did wrong when I swapped the injectors. One of the injectors I swapped with looked like it had carbon buildup on it. Could that be the culprit?* even though two failed the buzz test i swapped all 8 because I figured having 8 injectors with 6 months of driving is better than only have two new injectors and 6 old injectors.
** buzz test comes back strong on all 8 injectors.
Doing a cylinder contribution test, shows cylinder 8 being inconsistent. Could this injector be stuck open mechanically? I put the injector with the carbon build up on cylinder 3
#8 will almost always fail the contribution test, #3 sometimes acts up as well as #7 due to the oil and firing order. Take it as it is.
If buzz test was good so is the electrical side.
What CPS do you have and where was is sourced??
Air system in top notch shape from the not cracked air box (clean air) and fresh filter and CAC system pressure checked????
Outside conditions as well as truck temp?
Hard on the pedal when loaded, granny driven (fuel conscience)... maybe excessive carbon build up?
Injector cup clean and dry when doing install?
Pinched O Ring??? They were changed as well as the coper crush washer with OEM from the Ford counter I hope.
How much have you driven the truck since the swap?
What are you using to pull codes and run tests??? FORScan is the standard.
uh... you will get a lot of smoke and possibly odd behavior for a while until you drive it hard for a minimum of 25 miles. You have to get the air out of the system as well as residual fluids...which is accomplished from driving
I drove it about a mile after swap and didnt like that it was smoking. I mean lots of thick white smoke. I guess I need to pull them back out and swap copper crush washers and orings on it. My nephew is a mechanic at a shop and was saying I didnt need to swap the copper washers as they only have 6 months of use, but I have heard that they are one time use from you guys and another 7.3 guy. I think my nephew may be wrong. Can't say I am looking forward to doing this again but need my truck running right
Update. Driver side injectors re-installed with new washers and orings. Still smoking the same as before. Should i drive it for a bit and see if it clears up, or go ahead and do the other side?...
* tried driving it up and down the street, maybe 2 miles later, engine stopped, cranks but wont start up
Drive it! Get on the freeway if you can drive it hard off and on for ten miles each way and it should clear up if all else is good. One or two miles won't do that.
