Sponsored by: Real Truck
Help with smoke
Old Oct 18, 2025 | 08:33 AM
Greenpowerstroke's Avatar
Greenpowerstroke
4wd Low
Help with smoke
My 2001 f350 was having a little bit of a hard idle. I did a buzz test and two injectors failed. They were on opposite sides. I have a 99 f250 that i stopped driving.I swapped injectors on my 2001 7.3 with injectors off my other truck that had only 6 months of use. I removed and installed them with no error(to my knowledge). When starting the truck it was billowing smoke out the exhaust and under a little pedal it was worse than a coal train. I turned engine off, and went and did some running. After 3 hrs I started it up and no smoke under idle but still thick clouds under pedal. I am clueless to what I did wrong when I swapped the injectors. One of the injectors I swapped with looked like it had carbon buildup on it. Could that be the culprit?
** even though two failed the buzz test i swapped all 8 because I figured having 8 injectors with 6 months of driving is better than only have two new injectors and 6 old injectors.
Old Oct 18, 2025 | 10:08 AM
Split rims's Avatar
Split rims
Post your question in this sub forum.
https://www.ford-trucks.com/forums/forum31/
Bigoford
Dec 12, 2013 11:52 AM
Ford_250
Mar 18, 2011 06:49 AM
buckman123
Jan 27, 2010 06:18 PM
Dieseladdict
Nov 21, 2005 02:04 AM
