1978 - 1996 Big Bronco
1990 fuel pump problems
Old Oct 17, 2025 | 06:53 PM
Jkenosh's Avatar
Jkenosh
I bought a 1990 bronco that someone else took apart and I’m trying to get it back together. I bought a new fuel tank and pump and installed it and can’t get the pump to work, I dropped the tank and disconnected the lines, While I’m under the truck my wife walked by and I asked her to turn the key on, She turned the key too far to the start position and the pump turned on and shut off as soon as she stopped trying to start it. It doesn’t operate in the on position. What could cause this? Bad ignition switch?
Old Oct 17, 2025 | 07:56 PM
shorod's Avatar
shorod
Did that previous owner muck with the wiring? Another thought is you might have failed electrolytic capacitors in the ECM, but that typically results in the fuel pump priming and not shutting off versus not priming unless the key is on.
-Rod
Old Oct 19, 2025 | 07:19 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It sounds like the engine didn’t start so there was no signal from the distributor to keep the pump on.
Old Oct 19, 2025 | 12:08 PM
Jkenosh's Avatar
Jkenosh
It does start with starting fluid. As soon as it stops raining I will see what happens once it starts
Old Oct 19, 2025 | 03:02 PM
My4Fordtrucks
Does the pump stay running in the the RUN position if you jumper the terminals in the EEC self test connector?
BroncoRN
26
May 13, 2025 10:31 AM
xfrog
Dec 3, 2014 07:56 PM
stan'37
Modular V10 (6.8l)
Sep 16, 2013 08:12 PM
Heavy One Fifty
Feb 9, 2011 08:54 PM
chad1976
Nov 30, 2006 02:33 PM
