So I bought a 2019 F350 6.2. Good truck. Had the rear axle i needed for towing. Seat left something to be desired. I bought a set of seats from the local junkyard. They're the 8 way Power seat. I plugged them in and they worked. No adding wiring harnesses or anything crazy. But there's another plug under there and I'm thinking it's the heated seat plug. Can anyone tell me what to look for. The seats came from a 2021 F350.
That being said. What's the process for adding the switches to the climate controls below the stereo? Im thinking of going with the infotainment upgrade to sync 4 that is now out. Will this be an issue if I add the heated seat?
It's probably been asked a million times. So in any case. Any pointers in the right direction would be awesome.
You need to use the search function, someone posted up how to and I think linked to another forum but several folks have said they did it on this forum.
So I've been searching. And admittedly I'm not the best at searching through the foums as I haven't been on here in 12 years. But I cannot seem to find a direct answer to my question. Anyone got any guidance?
