302 or 351W?
Old Oct 15, 2025 | 06:54 PM
BCP9875's Avatar
BCP9875
Trailering
302 or 351W?
I have given up on the thought of keeping the '57 original with the 272 and 3 speed and have decided to modernize it a bit with a 302 or 351W and a 4 speed automatic. Leaning towards EFI and the Ford 4R75W transmission.
I would really like to go 351 if I can find a good specimen just for extra HP with minimal build but still want to build it some.
Has anyone stuck a 351W in their Fridge body with a more modern 4 speed auto and how easy was the transmission to get in there? Also we're you able to get headers on or have to go with manifolds?
Any thoughts or advice would be appreciated.
Old Oct 18, 2025 | 03:16 PM
MVClassics's Avatar
MVClassics
6th Gear
Has anyostuck a 351W in their Fridge body with a more modern 4 speed auto and how easy was the transmission to get in there? Also we're you able to get headers on or have to go with manifolds?
I swapped the 292 and 4 speed in my ‘59 for a 302 and a C4. There are conversion kits for the motor mounts and trans cross member. Really easy install. I went with a Lokar goose neck type shifter. It fit through the original shifter hole in the floor. Also really easy. New drive shaft completed this swap. There is plenty of room for long headers.
DP
Old Oct 18, 2025 | 03:34 PM
charlie g's Avatar
charlie g
FTE Community Team
351 aftermarket efi for simplicity aod trans
Old Oct 18, 2025 | 10:33 PM
Fomoko1's Avatar
Fomoko1
I have a carbureted but other wise stock 87 Crown Vic 5.0/225 hp/C4 automatic transmission in mine. I went with the carburetor for simplicity.
Old Oct 19, 2025 | 01:15 PM
tiresmoke410's Avatar
tiresmoke410
Crown Vic’s were 150 hp stock.
id go 351. It’s no more work and no more complication than a 302. But there is noticeable pay off in torque and potential power.
Old Oct 19, 2025 | 03:11 PM
Fomoko1's Avatar
Fomoko1
In 87 Crown Vic 5.0 was rated at 225 hp.
Exploring the 1987 Ford 302 Engine: Specs, Configuration, and Maintenance
breakfree
Mar 26, 2006 09:26 PM
Robert R
Jan 13, 2005 07:57 PM
jhk1981
Mar 23, 2004 04:56 AM
john22
Jul 27, 2003 02:28 PM
screwy
1978 - 1996 Big Bronco
Jan 14, 2003 07:57 PM
