Replacing battery terminals
Old Oct 5, 2025 | 07:06 PM
zackh123's Avatar
zackh123
1st Gear
My battery completely died so I figured I would re-do the old cracked terminals while I swap out the battery. Is there a secret on how to remove these cables from the old oem terminals? I don't see a pinch point anywhere where I can loosen.
Otherwise, is the solution to just cut the cables? The red one is pretty much at the minumum length needed. Is there a way to extend it?
Old Oct 5, 2025 | 08:06 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Nope. You already have one end of the cable removed from the battery. Follow the positive cable to the other end and disconnect it from the solenoid. For the negative cable disconnect it from the frame and engine block.
The solution is to go buy new cables.
Old Oct 6, 2025 | 01:44 AM
seschenburg's Avatar
seschenburg
If you want to go all the way, go to O'Reilly's or find another store nearby that will cut cable for you. I went one size larger than stock with mine. Measure for length, add several spare inches, and have them cut what you need. Add copper lugs to fit the fasteners. Marine heat shrink over the junction to seal the exposed cable, or maybe some liquid electrical tape. Military-type battery terminals so everything bolts together. Done. Never need to worry about it again. And if the terminals need replacing (sometimes they break if you tighten the clamp bolt too tight), it's simple to unbolt the cables and replace just the terminal.
Old Oct 6, 2025 | 08:01 AM
Hit Man X's Avatar
Hit Man X
Some lesser expensive brands work fine, SMP for example. HD ones, consider Custombatterycables.com they also sell components
wpg_250
Mar 16, 2025 08:25 PM
4wd6.7L
Feb 20, 2025 10:17 AM
Yooper mike
Motorhomes (Class A,B,C & Super C)
Jan 10, 2025 03:59 PM
dannac
2015 - 2020 F150
39
Oct 6, 2024 04:54 PM
Baja Fog
Oct 12, 2022 08:42 PM
