F808 = L800 gas, 31,800 lbs GVWR. This conflicts with the stated GVWR of 35,000 lbs. This was a special order truck and that probably allowed the higher GVWR
LP6 No info listed under these codes. I'll check another source tomorrow.
2CE
2 = indicates PTO
CE = Clark model 285VHD five speed direct transmission
EPP
EP = Eaton model 23221 two speed rear axle, 23,000 lbs capacity, 6.67 / 9.08 ratios
P = Rockwell (Timken) model FF-903 front axle, 12,000 lbs capacity, with power steering
141525
14 = Pittsburg District Sales Office
1525 = Special Order Number
If the original VIN tag is hard to read, you can also pull the factory-option details through a window sticker lookup ram https://carfast.express/en/window_sticker/ram style search, those services usually recreate the build info from the VIN and help confirm year, engine, and equipment on older trucks too.
