Hardware differences HO vs non-HO
Old Oct 1, 2025 | 04:56 AM
full_frame_chassis's Avatar
full_frame_chassis
Hello all,
As the title states. What are the hardware (not software) differences between HO and non-HO engines?
Are any of these pieces of hardware different between the two variants? Please cite information sources. Thanks.
- fuel pump
- injectors
- turbo
- charge air cooling
- pistons
- rings
- crankshaft
- cam and valvetrain
I read the Tech Folder and didn’t see this and spent some time looking for a thread identifying hardware differences between the HO and non-HO engines.
Thanks for any comments!
Old Oct 1, 2025 | 05:43 AM
F250_Super_4X4's Avatar
F250_Super_4X4
The main differences are:
Water cooled Turbo
6% over fueled injectors
HIgh volume CP4
2qt larger oil pan
​​​​​​​Stainless exhaust
Old Oct 1, 2025 | 05:49 AM
full_frame_chassis
Water cooled Turbo
HIgh volume CP4
2qt larger oil pan
Stainless exhaust
Thanks!
Are injectors physically/mechanically the same (same part number) between HO and non-HO?
Is the CP4 physically different or is it operated differently between HO and non-HO?
Old Oct 1, 2025 | 05:57 AM
Overkill2's Avatar
Overkill2
Water cooled Turbo
HIgh volume CP4
2qt larger oil pan
Stainless exhaust
We had a discussion here on the dipstick differences, and have shown how the upper oil pans through the different gens are the same dimensions, so I don't believe the pan is any bigger, unless you have documentation to show that it is.
Old Oct 1, 2025 | 06:16 AM
Superdave71's Avatar
Superdave71
I think all the latest gen 6.7’s hold 2qts more,
not just the HO
Old Oct 1, 2025 | 07:03 AM
Strider250's Avatar
Strider250
TFL talked with one of Fords engineers about the two engines and I have not been able to find where it has been posted here. The two engines are basically the same with only a few differences, the turbo, SS exhaust manifold, and some cooling changes. The fuel pump, oil pan and injectors are the same.
Old Oct 1, 2025 | 09:34 AM
Painted Horse's Avatar
Painted Horse
Here is the video that strider mentioned.
I can tell you that my 23HO runs about 150° hotter than my 2020 6.7L did.
So some of the changes for 23 were to handle the extra heat. Climbing a 7% road at 65 mph towing my horse trailer, I routinely see 1450-1475° on the my EGT1 Same trailer, same road, I'd see 1300-1325 on my 2020 truck.
I do use about 20% more DEF than my 2020 truck.
I do get about 10% better fuel mileage than my 2020 truck. The savings in diesel more than offset the extra DEF.
Regens are much shorter. In fact most of my regens are accomplished with Passive Regen. But the truck still initiates an active regen every 497 miles. But theDPF usually doesn't have much soot in it an the Active Regens are done it 5 to 10 minutes.
Old Oct 1, 2025 | 11:31 AM
Strider250's Avatar
Strider250
Here is the video, jump to 23:30 for the engine info.
Old Oct 1, 2025 | 12:17 PM
acdii's Avatar
acdii
The fuel savings is due to the shorter regen cycles. a 5 minute regen vs a 30 minute regen saves a LOT of fuel.
Old Oct 1, 2025 | 02:40 PM
Overkill2's Avatar
Overkill2
Old Oct 2, 2025 | 04:58 PM
acdii's Avatar
acdii
Considering the higher EGT's, the water cooling is a must.
dcbryan13
6.7L Power Stroke Diesel
42
Jan 26, 2025 11:48 AM
85F-350Dually
Jun 2, 2010 03:34 PM
skid pan
May 15, 2010 08:02 PM
Ranger92
Engine Swaps
May 21, 2008 03:00 AM
Laviathn
4 Cylinder Engines
Oct 2, 2003 05:53 PM
