Cork or rubber?
Old Sep 29, 2025 | 01:03 PM
tbruz's Avatar
tbruz
Cork or rubber?
I'm sure its been discussed before but what do folks recommend for valve cover and oil pan gasket replacements- cork or rubber?
I've gone back and forth on the valve covers a few times now- and yes the flanges/bolt holes are dead nuts straight/flat and mating surfaces are surgically clean.
I've had cork ones that get oil soaked and leak and rubber ones that dry out and leak.
Typically I use FelPro products but I am open for suggestions.
Thanks in advance
Tbruz
Old Sep 29, 2025 | 01:45 PM
tbear853's Avatar
tbear853
I have a couple sets of rubber with the metal core bought off Ebay. They weren't bad priced, branded as "Hot Rod Parts Supply". 3/16" thick rubber with steel core, they appear to be good gaskets ... billed as not needing sealant and as being reuseable. on steel or aluminum covers.
I long ago used to use cork, and once I had done some work on the truck and put new cork on, and unbeknownst to me, the lower portion on driver side slipped out. I went for a drive, made it a mile or so, saw smoke coming from under hood at rear. Knew enough to leave the hood shut, and turned around and high tailed it home where I stopped next to water. Shut it off, bailed out, grabbed the hose, turned water on, popped the hood. Sudden air and it blazed up, water cooled it though. Was near a quart low when next checked, soaked the exhaust, head, etc. Was a mess, but nothing a good clean didn't erase. I searched for a sealant. Charlie sold me a white product in a tube at NAPA. It worked on some new cork gaskets for quite a few years afterwards, but last I looked I could not find it. Charlie said they didn't have it either any longer.
The metal core will prevent that scenario. I do think is time to put a set on soon, so I guess I'll see if they are any good.
Last edited by tbear853; Sep 29, 2025 at 08:15 PM. Reason: Corrected source / brand (not Fel Pro)
Old Sep 29, 2025 | 02:55 PM
beartracks's Avatar
beartracks
Fel Pro makes a cork gasket that has a metal shim sandwiched in the middle. Mine have been on/off/on/off for probably 15 years or more!
Old Sep 29, 2025 | 04:32 PM
kenny nunez's Avatar
kenny nunez
Gaskets
The original Ford 302-351 valve cover gaskets are metal coated with some kind of rubber. Whenever I have to use cork I glue the gasket to the cover or the block. I prefer the silicone ones with the metal slugs which are reusable.
davidrozeboom1
May 17, 2017 08:37 PM
ladelld33
Oct 12, 2015 06:53 PM
mr_goodkat
Nov 20, 2012 06:32 PM
CCotten
Oct 12, 2005 09:29 PM
thynes
Nov 2, 2004 05:40 PM
