Valve cover gaskets
Old May 17, 2017 | 06:55 PM
davidrozeboom1's Avatar
davidrozeboom1
Valve cover gaskets
Okay what's the trick for these valve cover gaskets? I replaced them, immediately they leak, I had a shop replace them (he's willing to warranty work and parts) and they still leak. What's the trick?
Old May 17, 2017 | 07:42 PM
Filthy Beast's Avatar
Filthy Beast
What engine?
Cork or rubber?
If you have an FE and no oil restrictors you could get up to a quart of oil backed up in either head....leading to valve cover leaks 'cause the return oil flow can't keep up with the input.
As with any engine, over-tightening the VC bolts will lead to a distortion of the cover....and leaks.
If the valve covers aren't flat around the bolt holes....you' have a leak.
Old May 17, 2017 | 08:05 PM
HIO Silver's Avatar
HIO Silver
1. Hammer n dolly the flanges flat.
2. Wipe flanges clean to remove oil. I use acetone.
3. Run a very very thin bead of RTV on flange and around bolt holes. Let sit for 10 minutes before applying gasket. Let cure with the bolts in the holes to index the gasket.
4. Install and snug. Let the gasket do the sealing.. RechecK and snug after a few hot cycles.
Old May 17, 2017 | 08:37 PM
54Hydro's Avatar
54Hydro
I work at a machine shop/auto repair shop. The machine shop will use weatherstrip adhesive on valve cover gaskets. They don't leak.
cliftonsinclair
Feb 16, 2011 09:16 AM
Bear River
Aerostar
Mar 14, 2008 06:17 PM
brian.taylor
General Automotive Discussion
Apr 1, 2007 07:23 AM
Desert Dog
Bronco II
Jul 24, 2006 08:12 AM
FERacing66
24
Jan 14, 2005 01:11 PM
