Can I carry a ZF6 25'?
Old Sep 28, 2025 | 03:59 PM
540milotalon's Avatar
540milotalon
I figure a crazy title might get some
lookers.
There is a junkyard that is advertising any part you can pull and carry 25' for $55.00 plus any applicable core charges.
One day only! I just wonder if a slightly decrepit 60+ guy can carry one 25' or is this a "watch this" event in the making?
AI says it weighs 210 pound plus more if it has the T case mounted.
I used to pick up small and big block engine blocks by myself but the older I get:
"You just can't count on used to be like you used to could."
Old Sep 28, 2025 | 06:47 PM
helifixer's Avatar
helifixer
Great deal until you factor in a $50,000.00 back surgery and 4 to 6 months of recovery.
Old Sep 28, 2025 | 07:24 PM
ashleyroachclip's Avatar
ashleyroachclip
Once had a yard , with all you can carry for 25.00 each.
3 of us took buckets , ratchet straps and bunnies cords in , and when we came to the gate , they had to pick their jaws off the ground .
that was the end of that .
one guy was on crutches with a leg injury , packing buckets , and the other 2 of us used a Cougar hood up side down , with everything from carbs and intakes , to transmissions .
those were the days .
Old Sep 28, 2025 | 10:14 PM
540milotalon
The ad says "no bags" so we will be watched.
I have carried (5 years ago) my son's cast iron case T-19 4 speed close to that distance and put on the tailgate. I might can pull this off?
Old Sep 29, 2025 | 08:35 AM
knottyrope's Avatar
knottyrope
two poles to drag it or bring a dolly with big wheels
can separate the xfer case, only 6 bolts or so
Old Sep 29, 2025 | 08:44 AM
867.309's Avatar
867.309
Find some related jokes to help make 'em laugh when you show up. Keep them laughing and ask about a senior discount or something. Use the wheelbarrow and don't risk your back. Pay a little extra and possibly save a whole bunch.
ZF6 is cool but ZF5 is fine for me.
I keep cattle and have to compensate for my age continually. It's an ongoing process.
Old Sep 29, 2025 | 11:44 AM
Hit Man X's Avatar
Hit Man X
That trans is more than 210lbs, last I heard about 225. My S5-47 is about 170-180lbs dry.
Ask if they would let two folks carry it out for their fee. You will also be tired from pulling it, could roll an ankle or a knee buckles
Old Sep 29, 2025 | 06:50 PM
Lepidopterodactyl's Avatar
Lepidopterodactyl
The real "back breaker" (quite literally) isn't the carry; it's the 215lb deadlift you'll have to do before you even start walking. Lifting 215lbs off the ground is easier said than done for most people. I'd advise against trying it.
That_Guy
General Diesel Discussion
140
Jan 1, 2021 05:35 PM
khadma
Jul 4, 2017 07:56 PM
tow2atm
Oct 13, 2007 04:33 PM
lal357
Apr 6, 2003 02:49 PM
fatdaddy
Jan 14, 2002 09:43 PM
