2022 10’ display camera view when turning and towing
Has anyone figured out how to enable the mirror cameras to activate on the display when turning while towing with Forscan or something else? I believe the 2023+ do this.
I don't remember my 22 doing it, all my 23 pluses do it. I find it actually annoying. Very distracting.
A third party device is needed to enable side mirrors with turn signal
See I actually love it for trailering, absolutely eliminates the blind spot beside the truck when changing lanes, AND makes it so I can tell how close I might be to a curb if it's a tighter corner.
I DO wish I could get those same views when backing up, though...would be helpful on the 'blind' side of the trailer. They're probably trying to force me to get the trailer-mounted camera...
My toyhauler 5er has the Furrion/Lippert Vision S+ with 3 cams. Rear cam and right/left side cams. Added a memory card to the screen to record. The normal split display has the rear on the bottom of the screen and the sides together on top. When you signal, that side blows up full screen. The problem is the reaction is slow and I've often completed the lane change or turn before it activates so I turned it off.
