2003 Excursion replace ABS module
Old Sep 26, 2025 | 03:15 PM
thor363's Avatar
thor363
Anyone got a write up for how to get at and r&r the ABS module which is located on the front side of the ABS pump?
I need to pull it for inspection. Likely needs to have some contacts resoldered due to an intermittent ABS light problem.
Old Sep 28, 2025 | 04:51 AM
oharal's Avatar
oharal
I've been wondering the same thing for the same reason and the same suspicion lol. I took one look at it and realized I didn't have time to eff with it recently.
Old Sep 28, 2025 | 06:42 AM
01__Excursion's Avatar
01__Excursion
The inner wheel well liner has to come out if I recall....
Old Sep 28, 2025 | 11:09 PM
thor363's Avatar
thor363
When I'm done resurrecting my wifes 2007 Daytona, its next on my list. There has to be a way to get it out without breaching those abs lines to remove the pump.
Old Sep 29, 2025 | 06:38 AM
ncheavymetal's Avatar
ncheavymetal
FTE NC Chapter
I have had intermittent abs light issues on several occasions. Turned out to be the wiring harness connector from the speed sensor at the hub that connects to the module wiring harness. In front it's just behind the plastic wheel well cover. Going off road along with tire rub chaffed the wires.
I'm not saying this is your issue. But it was mine and I just had to replace the wheel sensor and connector and not the entire module.
Good luck. Let us know how it turns out.
Old Feb 27, 2026 | 05:51 PM
carlsson's Avatar
carlsson
So if the abs module is replaced, does it have to be "programmed" in order to function in my truck? If so, does anyone know a company that repairs these modules instead so it doesnt have to be programmed? How is the module removed from the abs pump assembly? I had a similar problem in my Porsche, and eventually found a specialty shop that repaired it, but Ford is a much different part.
ali iraq
Dec 10, 2024 02:42 AM
oresto
Sep 2, 2024 05:10 AM
Whitey Ford
Jul 10, 2022 09:41 AM
