2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
vents question.
Old Sep 23, 2025 | 03:59 AM
tjc transport's Avatar
tjc transport
i ain't rite
vents question.
is there any way to turn off outside air when heater/ac/defroster is not running on a 21 F150?
i know using the recirculate air button when running cuts off outsie air, but with system turned off, recirculate air also shuts off letting outside air through the vents.
Old Sep 23, 2025 | 05:01 AM
charlie g's Avatar
charlie g
FTE Community Team
sadly NO, same as when the system drops vacuum it goes to defrost,
Old Sep 23, 2025 | 09:12 AM
tjc transport
i ain't rite
Well that sucks
Old Sep 23, 2025 | 09:58 AM
jcnorton's Avatar
jcnorton
Not sure if I understand the question but on mine with the hvac turned off no air comes in. I use the power button on the hvac panel to turn it off, I use this in the winter when I pull out of the heated garage to not pump cold air into truck while engine heats up. Not sure if this would be the case with the truck turned off though.
Old Sep 23, 2025 | 02:16 PM
tjc transport
i ain't rite
with hvac turned off, driving down the road i get outside air coming into the cab through the dash vents.
Old Sep 23, 2025 | 03:39 PM
jcnorton's Avatar
jcnorton
You have me wondering if different trim levels would affect how that works. My 23 works that way, so did the 14 before it and a 17 Expedition we had for a while. Not that any of that does you any good.
tjc transport
Nov 27, 2020 05:47 PM
blake in spokane
Sep 28, 2020 08:21 AM
fladoodle
Jul 14, 2019 10:45 AM
superman64011
Jul 24, 2004 08:25 PM
u143349
Jun 4, 2003 10:06 AM
