Upgrading headlights
Old Sep 25, 2025 | 02:16 PM
Junktownbill99's Avatar
Junktownbill99
I use the Sylvania Silverstar ultra halogen bulbs. I like them, and they're quite bright. I do have clear lenses and big reflectors in my headlights though.
Old Sep 25, 2025 | 07:11 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by 1Butcher
I certainly would not remove relays if I had them installed.
My take about LED's is that they have way too many positives vs the negatives. Only if you get a good set. If you are buying a cheap set, you will not like them.
I just went with $30ish range LED bulbs. No complaints at all. I waited a few months to make sure they were ok then bought another set for the other truck. I just posted this photo in another thread.
Old Sep 26, 2025 | 12:43 PM
SCRebel's Avatar
SCRebel
I purchased LED Bulbs from Amazon, Sealight was the brand. They did great in my 2019 F150. However the light was very scattered, in the factory headlight of my 1990 f150. I ended up going back to halogen bulbs. Which aren't as bright but light the road better.
I think some of my issue is the factory style headlight have the fluted lens where some aftermarket light have the clear lens with a fluted housing.
I'm planning on upgrading to some aftermarket headlights where the fluted housing, installing the relay kit, and adding the Hella high wattage bulbs. I think that will work best for me. Not only because of my experience with LED bulbs, but also I'm running old school halogen daylighter lights, so it'll be a better match with what I have.
Old Sep 26, 2025 | 01:31 PM
SCRebel's Avatar
SCRebel
Originally Posted by Mudsport96
I bought new TYC factory housings and put in the relay harness kit. Then popped in some HELLA 80w/100w bulbs.
Work pretty dang good.
Low beams
High beams
I had LEDs at one point but they scattered too much with the factory style lens, and it gave me headaches.
Just the standard Hella bulbs? Or the Xenon?
Old Sep 26, 2025 | 04:52 PM
Mudsport96's Avatar
Mudsport96
pretty sure it is these
Old Sep 27, 2025 | 09:54 AM
1Butcher's Avatar
1Butcher
The 9004 bubs have a terrible connector that melts under normal bulb use. At least that is the experience I've seen with clients cars. Not certain how well they will hold up to even more current/heat. Without a doubt, I would relay those, before I installed the bulbs.
Old Sep 27, 2025 | 12:23 PM
Mudsport96's Avatar
Mudsport96
yeah they are relayed. And they are phenomenal
Old Sep 30, 2025 | 09:48 PM
camper357's Avatar
camper357
I did the same a few months back. New harness with relay and ceramic connectors. Now I can see at night. We will see if the bulbs hold up. Everything I read says they will burn out prematurely.
Old Oct 1, 2025 | 09:36 AM
1Butcher's Avatar
1Butcher
They don't burn out prematurely, they just have a shorter lifespan. Of course, if you don't drive at night often, then it does not matter.
Good thing you used the ceramic connectors. They should stand up to the additional current those bulbs use.
Old Oct 1, 2025 | 10:09 AM
Mudsport96's Avatar
Mudsport96
"It's better to burnout, than fade away"...... sorry couldn't help myself
Old Oct 1, 2025 | 10:19 AM
AuroraGirl's Avatar
AuroraGirl
A higher end bulb and proper voltage will have long life in convenional llamp?
The halogen effect actually cuases bulbs to replenish themselves under proper conditions
Old Oct 1, 2025 | 10:36 AM
1Butcher's Avatar
1Butcher
I'm no engineer but a brighter bulb probably burns at a higher temp. Especially when it's in the same size enclosure.
I've used 100w bulbs back in the early 80's when halogen was the only option. Yes, they were brighter, but they certainly did not last as long. It also puts a heavy load on your stock wiring harness. With the additional heat, you never know what the long term effect with the plastic headlight housing. Adding relays and connectors that can handle the extra heat is a good step.
For me, LED works.
Old Oct 1, 2025 | 11:42 AM
  #28
torq'ta 5 8's Avatar
torq'ta 5 8
Runflat
Oct 3, 2023 06:13 AM
wesward15
Jun 7, 2022 11:04 AM
rickles
2015 - 2020 F150
Nov 4, 2020 03:04 PM
