NOS Ford bedside
Old Sep 22, 2025 | 07:16 AM
0351mike's Avatar
0351mike
NOS Ford bedside
To all
I could use some guidance- I recently picked up a NOS Ford bedside for a 73-79
The mounting points for the tailgate hinge (basically ball and socket set up) and upper piece where the tailgate locks into bed have the mounting pieces that adjust on the inside like a door hinge, but the holes are not threaded- are these meant to be tapped to the correct thread size?
Old Sep 22, 2025 | 02:43 PM
Kman-S.E.USA's Avatar
Kman-S.E.USA
Originally Posted by 0351mike
To all
There should be caged nuts on the inside with threads, like the door hinges you mentioned have so they can be adjusted for fitment.
Old Sep 22, 2025 | 04:44 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 look for a caged nut on the inside of the area below the tail light. And use some anti-siez on them.
Old Sep 23, 2025 | 07:18 AM
0351mike's Avatar
0351mike
Yep- they are all there but smooth - no threads
this is a NOS bedside, maybe the guy that was supposed to thread them went to lunch that day and forgot?
Old Sep 23, 2025 | 09:04 AM
tbear853's Avatar
tbear853
Just guessing that you are referring to the inner bed side panel? Maybe the bed side panel is made like that to be threaded by a bolt that cuts it's own threads as the body shop technician or a robot runs it in the first time. I think is a 5/16-18 size.
Old Sep 23, 2025 | 10:25 AM
orangeford's Avatar
orangeford
Can you get a measurement of the size of the non threaded hole? Maybe use drill bits to find out? Then measure size of bolt/thread pitch that is supposed to go into it. See what the pilot hole size for that tap is and compare? It makes sense that they may have planned on using a self tapping bolt.
Old Sep 23, 2025 | 01:55 PM
0351mike's Avatar
0351mike
Thank You both
I will give that try
Old Sep 23, 2025 | 06:44 PM
77&79F250's Avatar
77&79F250
So you DO have the caged nut back there, it is just not threaded, correct?
Old Sep 24, 2025 | 12:53 PM
0351mike's Avatar
0351mike
Yes all the caged nuts are on the bedside, but all without threads. I am assuming i can get the correct bolt sizes of the original and use a tap and die set
gstrom99
Sep 22, 2025 09:19 AM
KIKKUP
Dec 12, 2012 10:18 PM
9d4
Nov 16, 2007 12:38 PM
billpool
Jul 22, 2007 10:51 AM
