Snapped front crank bolt. Next steps?
Old Sep 21, 2025 | 02:42 PM
Lex2002's Avatar
Lex2002
The front crank bolt at the main pulley/harmonic balancer snapped. (Do these trucks have a harmonic balancer? Not sure.)
How, you ask? I was turning over the motor over by hand with a long pry bar, then went to turn it over with starter after (injectors werent in), forgot the long pry bar was mounted, it then hit something got caught and BAM...it snapped.
Is the motor toast? Salvageable?
Old Sep 21, 2025 | 03:16 PM
Kintla's Avatar
Kintla
I'm surprised it snapped like that. I've used the starter to break crank bolts loose, though I guess not giving it room to move the breaker bar first. That's a bummer.
How much of crank bolt sticks out or is it snapped off flush? I bet you could weld a nut on there and get it out without too much fuss.
Old Sep 21, 2025 | 03:26 PM
uglypitbull's Avatar
uglypitbull
ouch...those are 212ftlbs of torque too. I wonder if its best to try and drill that bolt out now. I think that torque value is no longer applicable since the head of the bolt is gone...maybe a reverse drill bit could get it out.
Old Sep 21, 2025 | 03:29 PM
JoshHefnerX's Avatar
JoshHefnerX
How far down in the hole is it broken? With the head off, the stretch is relieved on the bolt. So there shouldn't be a ton to torque holding it in place.
Old Sep 21, 2025 | 03:52 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I agree, should be relatively easy to pull as there's no mechanical tension applied to it any more.
Old Sep 21, 2025 | 07:11 PM
RA101725's Avatar
RA101725
Banned
That crankshaft pulley is the harmonic balancer or “vibration dampener” as Ford calls it.
might as well pull it off and get a new one and also a new Melling 208 oil pump because the front seal and old balancer is probably tired from age anyway. The bolt I know Riff-raff sells. (I might have a new Motorcraft balancer I’ll let go for a good price if you’re interested…I bought a Fluidampr and never used it.)
I’m not a broken bolt bolt extracting expert but it’s a common thing to deal with. Maybe not THAT particular bolt…I doubt too many people break these under normal circumstances considering how big it is. That starter is no joke and obviously it was trying to tighten it otherwise it would have broken it loose and started backing it out.
Old Sep 21, 2025 | 08:01 PM
RA101725's Avatar
RA101725
Banned
so the motor must spin clockwise if holding a right hand thread bolt steady with a breaker bar causes it to loosen? Spinning the motor clockwise while holding the bolt steady accomplishes the same thing as holding the motor steady and spinning the bolt counter-clockwise, so I’m trying to figure out how the bolt didn’t just break loose when it whacked against the frame.
Also I always thought the fan clutch nut (also right hand thread) was trying to tighten itself against the rotation of the engine, but that’s not really true I guess if the engine spins clockwise. Holding the nut steady with a wrench against the rotation of the engine would start backing if off.
Old Sep 21, 2025 | 08:02 PM
Lex2002's Avatar
Lex2002
I havent checked how much bolt is sticking out. I was too pissed off, I had to walk away.
I just assumed the other components would be damaged as well in the process. Am I wrong?
Old Sep 21, 2025 | 08:07 PM
Lex2002's Avatar
Lex2002
It must have spun the breaker bar until it hit something in the engine bay. When I went under the truck, the breaker bar was hanging straight down with gravity, not jammed into anything and the 24mm nut was turning....I need to double check it in the light tomorrow.
I will report back.
Old Sep 21, 2025 | 08:48 PM
Kintla's Avatar
Kintla
I'd be surprised if anything other than the crank bolt broke, but I'm still surprised that it broke instead of coming loose. Has the crank bolt been out before? Wondering if there was some serious loctite on it?
If you can't weld a nut on it a machinist will be able to get it out worst case.
I'd NOT recommend trying an ez out. You're just going to end up with a piece of hardened steel broke off in your crank bolt making it harder to get the broken bolt out.
Old Sep 21, 2025 | 10:50 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Did the same thing on my 64 Lincoln, but nothing broke.
Glad I'm not alone in that particular club anymore.
Old Sep 21, 2025 | 11:28 PM
callforfire's Avatar
callforfire
Wait. Are you sure it's broken? I ask because this part...
I will report back.
This makes it sound like it is just broken loose. You should be able to just remove the bolt the rest of the way and post up a pic of either the bolt or the part that snapped off.
Maybe I misunderstood you, but it does sound like you can torque it back down and be fine... depending on if the breaker bar smashed anything else.
Old Sep 22, 2025 | 06:48 AM
Dan V's Avatar
Dan V
I will report back.
It's not a nut.
Old Sep 22, 2025 | 08:30 AM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by Dan V
It's not a nut.
I read that in Schwarzeneggar's "It's naht a toomah!" voice.
But I agree with the others in that the bolt is probably just loose.
Old Sep 22, 2025 | 09:07 AM
kenn_chan's Avatar
kenn_chan
that would be the best result, a little freaky for the OP but much better than snapping it.
