Upper fuel filter
Old Sep 19, 2025 | 05:34 AM
Hmcfly626's Avatar
Hmcfly626
Upper fuel filter
Was just wondering if I need to change my upper fuel filter on my 2017 6.7. I have a FASS system on the bottom end. I'm finding it hard to find just the upper; all I'm finding is the conversion kit to go from plastic to metal. Is it worth going that route or not?
Old Sep 19, 2025 | 06:30 AM
rufushusky's Avatar
rufushusky
Ford and most aftermarket companies make fuel filters for the 6.7 in sets. You are going to have a hard time finding just a upper filter for a 6.7. You could just get the cheapest kit out there and keep the upper filter as a filter of last resort however the downsides to that are the waste of the lower filter and the fact you are getting a cheap upper filter that could turn into a diesel fountain on you.
I have the fleece upper filter delete on mine (I am not running a FASS, I still have the OEM low pressure pump), silly easy install and I am using the extra port for low side fuel pressure. HSM makes a nice upper filter delete as well. I don't like how Fass forces you to cut the injector return on their upper filter delete but that is an option as well.
Additionally you could get the small 3/4-16 post filter spin on replacements for the upper filter and have that as the final filter in the system.
https://hs-motorsports.com/collectio...conversion-kit
However, the profile of the upper filter really relegates you to a tiny filter. There are 4 micron options but they are OEM spec on 75-100 hp skids and mini-excavators with 3.3L engines. You are definitely running them above their effective flow rates on a Cat 1R0749 which can be found on anything from a C9 to a C18, you definitely are staying within what the filter is capable of.
Just my humble two cents, don't run FASS' filters run aftermarket. The swelling media on their water separator is asking for trouble with a CP4 IMHO.
https://www.fassride.com/filter-cross-reference-sheet?srsltid=AfmBOoqTj8BubVnPzBWhSLyoC9wglrqq3hqu ma57-UtMSRiVhagB0TEp
I have the Baldwin BF7587 as my secondary filter and Cat 175-2949 as my primary/water separator. Both of those would work on a fass pump.
Oh and someone is going to link the S&S video with rust in spin on filters in 3...2...1...
Old Sep 19, 2025 | 08:45 AM
Digger196's Avatar
Digger196
Buy this -
Fleece Engine Mounted Filter Assembly | 11-24 Ford Powerstroke 6.7L | Thoroughbred Diesel
mxer0022
Dec 17, 2024 11:20 AM
Fmc128
Mar 12, 2024 11:33 AM
tothe birds-a
Sep 21, 2020 07:17 PM
Canaan Morgan
Sep 7, 2018 11:17 PM
