Fuel filter P/Ns
Old Oct 5, 2021 | 12:46 PM
mxer0022's Avatar
mxer0022
Fuel filter P/Ns
Anyone know what the difference is between the FD-4625-AA filter kit and the FD-4641? Getting ready to make my first fuel filter change and am confused as hell.
Old Oct 5, 2021 | 04:46 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
There is a thread on this, just in the last couple of days.
Far as anyone can tell, filters are the same, the 4625AA kit comes with a plastic clip that isn't needed on later trucks.
My owner's manual for my 2022 lists the 4625AA as the current kit.
Old Dec 14, 2024 | 11:31 PM
jmarkley's Avatar
jmarkley
2nd Gear
FD 4641 vs FD 4625 (2022 F250)
Hello, I’m new to this forum, wanted to share…I’ve recently learned (today) that FD 4625 filter does physically differ from the FD 4641. On FD 4641 (oem part for 2022), the “outlet” port is apparently slightly larger diameter than the “outlet” port on FD 4625. Barely noticeable in general appearance. I discovered this when replacing the oem (4641) filter with the newer filter provided (Motocraft, FoMoCo part FD 4525).
Once connected, the outlet port of FD 4525 readily leaked during priming (yes, proper attachment/seal during install), this occurred several times/attempts. Also interesting, the 2 other ports on FD 4625 may possibly be a hair larger in diameter, as all 3 fittings seems a bit loose after attachment. However, only the “outlet” (center) port was noted to leak (strongly).
Intermediate remedy was to re-install oem (4641) filter. This was completed without difficulty, complication, or any evidence of fuel leak.
I plan to follow up with the vendor, as I’ve also noted when the original order for filter was placed, the part number requested was FD 4641 (kit), after looking more closely I did in fact receive FD 4625 (also a kit). The parts received (both filters) are extremely close in physical appearance and fit. The tank based filter (included with FD 4625) was exact to oem and replaced without any problem.
Another finding pertaining to the FD 4641 (kit) is that the engine bay fuel filter, per original (correct) order reflects the following identification (LC34-9150-AA, as viewed in the original order pictures)- this identification matches oem engine bay filter (LC34-9150-AA). I’ve included a picture of the oem engine bay filter ID below. The engine bay filter, which leaked and was included in FD 4625 (kit) does not have the same identification as oem part noted above.
Further internet search provided the following details:
“The Motorcraft FD 4641 Fuel Filter / Water Separator Kit is a genuine OEM replacement filter for your 2022 - 2023 6.7L F-Series Ford”.
FD 4625 kit includes fuel line reinforcement collar, this is not applicable to 2022 (and newer) vehicle.
I realize this is a lengthy read, only wanted to share detailed response/direct experience to the following inquiry- “Anyone know what the difference is between the FD-4625-AA filter kit and the FD-4641? Getting ready to make my first fuel filter change and am confused as hell”.
Hope you find this experience and details within to be helpful. In short, if you have 2022 (or newer), FD4641 is believed to be most accurate.
Old Dec 15, 2024 | 07:25 AM
chadstickpoindexter's Avatar
chadstickpoindexter
My first question is, where did you order the filters from? There are a lot of fakes out there, and it’s things like this that make them fakes. I make sure to only order mine from reputable sources, which means no Amazon or eBay.
My 22 started with the 4625’s, which eventually went to the 4641’s and I have had no issues, including the leaking you describe. Also, for what it’s worth, now they are going to the 4647’s…
Old Dec 15, 2024 | 09:44 AM
speakerfritz's Avatar
speakerfritz
One of these filters now has an internal by pass valve ..when the bypass valve activates..you have no filter.
Old Dec 15, 2024 | 02:14 PM
jmarkley's Avatar
jmarkley
2nd Gear
Agree with chadstickpoindexter
Yes, did purchase from reputable (Ford) dealership. Interesting and curious about the available inventory (at time of order) as now to now the part number does indeed show “discontinued” for 2022 F250, online Ford OEM parts.
You are also correct about change to FD 4647, although this is difficult to search within the online parts database.
Link below provides pointers to aid identifying “Fake” from OEM.
Old Dec 15, 2024 | 03:09 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
The FD4647 is an updated design, has quite a bit larger reinforcement ribbing up top of the engine mounted filter to counteract any cracking.
Old Dec 15, 2024 | 03:37 PM
speakerfritz
yes…I think that is the one with the by pass valve.
the by pass valve kicks in if the media can’t handle the flow demand be it becuase of cold weather geling or even bio matter from bio blends . Once the bypass valve kicks in, your injectors become the fuel filter.
Old Dec 15, 2024 | 05:32 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
And, I still maintain that you are incorrect about how that works.
Plus, that literature that you posted about the bypass was on the 4625 filter number.
Old Dec 16, 2024 | 12:08 PM
rufushusky's Avatar
rufushusky
The bypass has been in circulation since 2021 or early 2022, it has kicking around for a while now.
I don't love it either honestly, dodge and GM at least give their end users a fuel heater but FoMoCo abandoned those 20 years ago, but given the recirculation valve at the tank, the amount of 10 micron fuel is somewhat limited and I haven't seen thread about injectors falling from the sky yet.
Old Dec 16, 2024 | 02:24 PM
jollyrogr's Avatar
jollyrogr
I think Ford decided that running the CP4 dry is worse than temporarily bypassing the secondary filter.
Old Dec 16, 2024 | 04:16 PM
FishOnOne's Avatar
FishOnOne
Agreed... And the Bosch injectors have been proven to be extremely reliable so it can be assumed Fords filtration is doing a good job.
Old Dec 16, 2024 | 04:19 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
The pump is never "dry", diesel fuel is oil, it doesn't dry up very quickly, so even if fuel flow is down to the pump, there is still fuel in it coating the workings.
Old Dec 17, 2024 | 11:20 AM
elee3's Avatar
elee3
It’s interesting that he FD-4647 filter is less expensive than FD-4641. On Rock Auto the difference is $27.
DSMMH
Feb 24, 2010 01:16 PM
61 uni
Nov 22, 2008 08:20 AM
RoyalFord
1997 - 2003 F150
29
Aug 21, 2004 02:52 PM
lordconqueror
1983 - 2012 Ranger & B-Series
Sep 8, 2000 01:12 AM
