Sponsored by: Real Truck
6R140 Service
Old Sep 10, 2025 | 12:01 AM
Aaronw12's Avatar
Aaronw12
6R140 Service
I've had my 2012 F-250 since 220,000 mi it now has 228,000 mi. Thinking of changing the transmission fluid, not sure when it was done last. It still looks clean on the dipstick, maybe not quite as bright red as new but close. What's the best thing to do here, drain and fill and replace the filter? Or a couple drain and refills then replace the filter on the last refill?
Old Sep 10, 2025 | 06:37 AM
2015 F-350's Avatar
2015 F-350
IMO if you don't know the condition of the transmission, drop the pan and change the filter. This will give you the opportunity to view the internals, look for debris in the pan, clean the magnet, and open the filter to look for debris also.
If the unit hasn't been serviced, there will be clutch material from the clutch packs and probably some from the TC also in the pan that needs to be cleaned out.
Please keep us updated on what you do.
Old Sep 10, 2025 | 08:23 AM
Overkill2's Avatar
Overkill2
No doubt I would do a drain, pan drop for new filter and fill. Clean off magnet if need be.
When I had my 96 F250 that I commercially plowed with, I would do a driveway "flush" (wife in the driver's seat) as I had a two valve set up in the trans return line back. It had a B&M extra capacity trans pan, bigger trans cooler and another external trans filter from Diesel Site, but my point to this is I bought two cases of ATF to do the drain and fill twice. The 6R140 holds 17 quarts and the pan drains out about 8 quarts. So if you do it twice, yes you will dilute the older fluid with more fresh Mercon LV fluid if you feel more comfortable with not knowing the last time fluid was dropped.
Old Sep 11, 2025 | 01:04 AM
Aaronw12's Avatar
Aaronw12
Not quite following here, you had a valve set up allowing you to pump fluid out of the transmission while the engine was running and added new fluid into the dipstick tube while the old was being pumped out?
Old Sep 11, 2025 | 08:43 AM
WWR's Avatar
WWR
It's up to you but would probably be nice to change the filter and establish your own base line. After that you could just do spill 'n fills at whatever interval you like.
I just used Maxlife in mine, but today I'd probably use Maxlife Extended Protection or the DexVI/Merc LV stuff -- whichever is cheaper. The 6R140 doesn't seem that picky about fluid.
Old Sep 11, 2025 | 09:35 AM
Overkill2's Avatar
Overkill2
On my 96 F250 plow truck, I bought a two way valve from dieselsite.com and installed it in the return line.
I would shut off the return line and open the tee line. My wife would start the truck, shift through gears down and back up. As soon as it started to spit air, I'd have her shut it off.
The truck had a bigger aftermarket cooler installed, I removed the factory one and installed a Tru-Cool 40k GVWR cooler, as well as one of the aluminum finned coolers from EBay and a spin on filter head with filter from Dieselsite.com.
I would then add at least 8 quarts of Mercon whatever I used at that time, it also had a B&M extra capacity trans pan, let it run and mix. Then do it again before plow season.
I heard horror stories about stock E4ODs and wanted it to last, which it did, as I plowed in some of Buffalo's worst storms >> lake effect.
Old Sep 11, 2025 | 03:38 PM
crashz's Avatar
crashz
The 6R140 is an easy transmission to change the fluid on. Even removing the pan is pretty easy as long as all of the bolts are in good shape. Fluid and filter and then follow up with just a fluid drop a couple days later. Technically I believe 3 fluid drops gets the fluid condition to about 80-90% new. Now is the time to do it.
Old Sep 11, 2025 | 08:07 PM
Overkill2's Avatar
Overkill2
x2... it is easy to service with the drain plug. If I were you, I'd do two drain and fills and look into LubeGard's trans additives...
I've done about three 30k mile drain and fills with mine, give or take, and will be doing my fourth before winter soon... trucks at almost 143k miles and it went out longer than I wanted... just past 50k miles. I have LubeGard's Platinum ATF additive that I have used before, and bought their Aluminum protectant additive as well that I recently discovered.
Up to you, but LubeGard has additives that are recommended by OEMs... you can find them on Amazon. Good luck.
dflaherty10912
Apr 11, 2025 05:52 AM
CMcGee
Jul 12, 2024 07:34 PM
Rhizzlebop
Feb 4, 2024 08:47 AM
97F250XLT
Apr 18, 2009 08:39 AM
skier-24
Nov 23, 2006 07:47 PM
