2011 E250 4.6
Old Sep 9, 2025 | 05:08 PM
Dirty Dee's Avatar
Dirty Dee
2nd Gear
2011 E250 4.6
Will a new Flexplate fix this issue??
File Type: mp4
Old Sep 10, 2025 | 08:09 AM
manicmechanic007's Avatar
manicmechanic007
Maybe,
Pull the starter and examine the teeth on the ring gear and bench test the starter drive
Bench test the starter drive by seeing if the drive can chew up a 2x2 without slipping and making that noise
Ever done that test?
Starter on the ground, running with jumper cables, test drive with big stick pressing real hard into the gear teeth
It should send wood flying
Do it, Hopefully the ring gear is not shot
but,
I am helping a guy replace his on a '13 F150 next week
Old Sep 10, 2025 | 11:24 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Can barely hear it from inside the car.
Bendix might be bad, one or both gears might be bad.
I agree with @manicmechanic007, pull the starter and see what you can see.
catr3
May 15, 2024 08:08 AM
wotan
17
Nov 5, 2013 09:08 PM
1'snotenuf
May 21, 2013 02:15 PM
kindashort
Jul 10, 2010 12:10 PM
75highboy
16
May 15, 2009 11:44 PM
