Startup procedure following HPO resealing
Old Sep 9, 2025 | 04:12 PM
HPOP_hater's Avatar
HPOP_hater
4wd Low
Truck died going down the highway a month back, got it home and did an air test, heard a leak someplace in the V so I did PPE standpipes (bottom of one of the standpipes was hammered out), resealed the HPOP and did the seals in the J tube as well. Got everything back together last night, unplugged the FICM relay and got to cranking. Did a few minutes of 15 second cycles and nothing came of it. Air tested it again and it held pressure. Put a 3000 psi gauge into the ICP port and the needle didn't even move. Am I missing something or does it take hours of cranking for it to eventually fire?
Old Sep 9, 2025 | 04:50 PM
bismic's Avatar
bismic
What year? Late '04 possibly?
Post a pic of the top of your engine.
In this thread you said it started:
https://www.ford-trucks.com/forums/1...or-idling.html
Old Sep 9, 2025 | 06:47 PM
HPOP_hater's Avatar
HPOP_hater
4wd Low
It is a late '04, has 2 piece standpipes and wavy oil rails, round HPOP.
Old Sep 9, 2025 | 08:03 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yeah, it can take a concerningly long time. And can be surprisingly sudden when it does catch.
I normally pull the FICM relay and do 4-ish 20/30 second cycles before even trying to put fuel to it.
Old Sep 11, 2025 | 04:12 AM
Hartwig's Avatar
Hartwig
How often did you cranked it for 15 sec.?
Old Sep 11, 2025 | 05:56 AM
TooManyToys.'s Avatar
TooManyToys.
Old Sep 13, 2025 | 10:43 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
This explains the procedure quite well. Every time I do an oil cooler or headgasket job, I always refill the oil at the oil filter housing first.
jessev1978
Feb 11, 2019 08:35 PM
F0rdF0rever
Feb 8, 2019 03:13 PM
colt373
Dec 16, 2018 02:25 PM
Jgard00489
Jul 3, 2016 02:19 PM
Frosty67
15
Mar 9, 2015 06:45 PM
