No start 2000 excursion 7.3
Old Sep 6, 2025 | 12:12 PM
Tylerconn's Avatar
Tylerconn
1st Gear
Hello all so I have a 2000 excursion limited with the good Ole 7.3 250k miles yesterday truck just died on ne and will not start has codes p0380 p1262 p1278 replaced uvch and swapped in a known good idm fired right up passed buzz test etc drove down road and died again same thing now have codes p0380 p1262 p1278 p1298 p1293 p1294 p1296 not sure where else to start idms are not cheap lol uvch has been replaced with pigtails now crank no start
Old Sep 7, 2025 | 01:38 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
And my questions would be this..
Where did you get your parts?
What were the names on the packaging?
Old Sep 12, 2025 | 08:22 PM
97-psd's Avatar
97-psd
Do you have a spare CPS? I would swap it out. What brand of parts did you use?
Old Sep 25, 2025 | 12:15 PM
story352's Avatar
story352
Seeing that many codes I would check your engine harness very carefully, especially at the drivers side valve cover where it seems to chafe on the valve cover. It may be more beneficial in the long run just to order a new engine harness since it comes with new UVCH connections, I never splice in new connectors there. Pull your valve covers and make sure none of the wiring that is supposed to be zip tied out of the way is pinched under the valve cover or cracking. If I had to guess the problem is somewhere right there on top of the engine.
kyletesmer13
34
Nov 26, 2023 10:53 AM
D.D.7.3
Feb 2, 2022 09:58 AM
Carlton1982
Sep 14, 2021 12:50 AM
G$cashford
Feb 29, 2020 12:23 AM
msmith0310
General Diesel Discussion
Jun 7, 2011 01:25 PM
