distributor gear sheared...
Old Dec 10, 2003 | 05:29 PM
banky's Avatar
banky
Yes, it is the same one that has been in the motor. I tried another one from another 351w that i have, and the gears are wearing out on it, but not sheared right down and broke off like the other one. It did not stick out of the block, so maybe the shear pin hole is higher. Still, it should be the same distributor I would think.
From this point though, the truck will not start now.
thanks RTM, I appreciate all your help.
banky
Old Dec 10, 2003 | 05:52 PM
RTM's Avatar
RTM
Did you replace the cam in this motor? I just recalled a buddy of mine that had a 460 motor do the same thing. He had the dizzy measured and even had the block measured and all checked out perfect. He got rid of that cam and installed another new cam and never had another problem with the pins shearing or tearing up the gears.
Old Dec 10, 2003 | 10:38 PM
MatthewP's Avatar
MatthewP
Minimum clearance between distributor gear and cylinder block is 0.050". Minimum shaft end play between distributor and oil pump is 0.008" to 0.010".
These specs are as supplied with part M 6605 A341, hardened oil pump drive shaft for 351W application.
-Matthew
Old Dec 11, 2003 | 03:15 PM
banky's Avatar
banky
Thanks for the specs Matthew, I will check this stuff on the weekend...if possible...
banky
Old Dec 11, 2003 | 06:14 PM
MatthewP's Avatar
MatthewP
Good luck - I hope you solve this frustrating problem.
-Matthew
Old Dec 14, 2003 | 11:10 AM
WALJON's Avatar
WALJON
IT totally sounds like the gear on the cam check it again sometimes its hard to see down there WHAT els could it be to much end play in cam??
70f250highboy
1978 - 1996 Big Bronco
Jul 28, 2014 01:21 PM
robsmaze
Mar 3, 2008 11:56 AM
wfo4me
29
Jun 14, 2006 10:18 PM
banky
Sep 11, 2003 05:44 PM
