Tire pressure
Old Aug 30, 2025 | 11:48 PM
Bobby Detecting's Avatar
Bobby Detecting
Tire pressure
Hello everyone I just had a set of 235 85 16 firestones put on my 1975 ford f250 and had them set the rears to 80 psi and fronts to 60 for a better ride could I set to rears to 60 as well for a better ride or is that too low what the lowest I can go in a 10ply tire like that that is safe thanks?
Old Aug 31, 2025 | 12:25 AM
Rubiranch's Avatar
Rubiranch
I had a set of bias ply 7.50x16 and ran 35 rear and 40 front.
I now have a set of LT 285/75Rx16 and run 40 rear 45 front.
80 psi is max with the truck fully loaded and 80 psi makes for a horrible ride ride.
Old Aug 31, 2025 | 12:11 PM
79F150400M's Avatar
79F150400M
What Rubiranch said....running them at full pressure is a harsh ride. I run mine at 42 in the front and 38 in the rear. I only pump up the rear tires when I pull the 26 ft Evo and 50 psi is enough to do the job. This is actually on my 2019 F150...but also applies to any truck running 10ply tires.
Old Aug 31, 2025 | 01:13 PM
Pickupmanx2's Avatar
Pickupmanx2
Yes, drop them down, a lot! On my 77 F250 4x I run 35 F and 30 R unless I'm cutting wood, then I'll bump the R up to 45, when off-roading I'll drop down to 20 F and 15 R, none of my trucks are at "recommended" pressures.
In mid 2000's I lucked into a 97 F350/CC/4x/7.3/ZF5 for a very very nice price, even for back then due to the owner having all the tires at 80psi, all the shocks adjusted to max.. it drove/rode absolutely terrible and everyone that looked at it previous to me walked away because of it he told me. We agreed on the price, dad and I went down the next day with $$, signed title and took off, got a mile down the road and pulled off, aired down the fronts to 45, R to 40, dropped all the Rancho's down to 0 and viola! Truck only had 50k on it, also had a BD exhaust brake and Gear vendor OD unit!! Still kick myself for selling that one!
Old Aug 31, 2025 | 05:14 PM
Bobby Detecting
Tire pressure
Yes I drop them to 60 all the way around it's a show truck with low miles so what would you guys reccomend for just a smooth ride driving like I said it's a fun show truck so just for a nice ride but not too low where I would have a problem thanks?
Old Aug 31, 2025 | 08:17 PM
Rubiranch's Avatar
Rubiranch
35-40psi rear
40-45psi front
Randy Spiker
Apr 10, 2022 12:48 PM
finnf250
Mar 23, 2018 05:43 AM
N600
Large Truck
Apr 6, 2014 08:59 PM
jdadamsjr
6.7L Power Stroke Diesel
Apr 26, 2012 11:09 AM
bigjako
May 20, 2010 10:47 PM
