rear diff broke?
Old Aug 27, 2025 | 06:20 PM
rc70070's Avatar
rc70070
3rd Gear
rear diff broke?
Guys
Havent been on here in more than a long time. Son has a 2011 f150 lariat with the 6.2l with the #7700 tow pkg. axel is noted as “b6” which is 3.73 limited slip….is it the 8.8 or the 9.75”
I ask because due to way to big tires 40” on 6 or 8” lift and tik tok mechanics not changing gear ratios…. The rear wheels locked up while at an intersection…. I am assuming that the whole differential went out. Thoughts on price wise swapping axel? Or just gearing inside diff? Thought? It got towed to a dealership which I don’t believe is the most cost effective of course but was close by on a Saturday hour away from home. SO I guess do you guys think it is just everything blown behind the differential plate? I have a hard time believing that the actual axel is a issue?
Old Aug 30, 2025 | 09:03 AM
steve(ill)'s Avatar
steve(ill)
dont think you will know for sure untill you spend 15 minutes taking off the rear cover and a quick look inside.... Even the dealer can do that and give you an ESTIMATE.
normal mode of failure would not be a total LOCK UP.
|WYG|SS
Nov 4, 2009 09:14 AM
bradmurd
Jan 10, 2008 08:55 PM
d0n_3d
1997 - 2003 F150
Jan 3, 2005 09:01 AM
Bronco3
1978 - 1996 Big Bronco
Oct 16, 2004 01:37 AM
