92 LS and Non LS diff
Old Jan 10, 2008 | 06:14 PM
bradmurd's Avatar
bradmurd
I am putting in a front end from an 88 f150(19, 3.55 NON LS) into my 92(H9 3.55 with LS)
will this be an issue, the gear ratios are the same but i will have LS in the rear and non ls in the front when in 4x4..will this cause any damage or am i good to go. i do know if the gear ratios are different it wont work but wasnt sure about the LS or not
thanks for any advice
-brAd
Old Jan 10, 2008 | 06:24 PM
351slug's Avatar
351slug
Your right, as long as the gears are the same your good to go.
Old Jan 10, 2008 | 06:52 PM
Dustin1690's Avatar
Dustin1690
Yeah as long as the gears are the same your okay only thing is with limited slip in the rear 2 wheels will spin when the one starts spinning and only one in the front will spin while in 4x4 so if you had ls front you would have 4 tires spinning in 4x4 i think anyways
Old Jan 10, 2008 | 08:55 PM
bradmurd's Avatar
bradmurd
ok thanks just needed a second opinion
appreciate it!
