Air pump bypass
Old Aug 25, 2025 | 07:06 PM
Hurley?'s Avatar
Hurley?
8th Gear
Air pump bypass
I’m looking into bypassing/ getting a belt small enough to skip past the air pump on a 94 5.0. Is there anything I need to do if I do bypass it and what size of belt would I need?
Old Aug 26, 2025 | 06:08 AM
manicmechanic007's Avatar
manicmechanic007
Just know if you quit spinning your air pump for a while it will freeze up and be no good afterwards
Takes a while, but they freeze up
And
We all breathe the same air
Old Aug 26, 2025 | 09:40 AM
wwhite's Avatar
wwhite
Get a string and measure.
Or, get the by-pass bracket and pulley, and use your stock belt.
Or, gut your air pump, and use it as a idler pulley.
Old Aug 26, 2025 | 10:40 AM
Scndsin's Avatar
Scndsin
Go over to the search box & type in "air pump delete" with quotes.
You'll find all you need to know.
Old Aug 26, 2025 | 11:38 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Boie Howdy...will you ever!
Old Aug 26, 2025 | 11:57 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The point of this is what? Does the air pump work? Are you removing the whole air injection system?
Old Aug 26, 2025 | 12:07 PM
Scndsin's Avatar
Scndsin
There's only so many times the same words can be typed...
Old Aug 27, 2025 | 06:01 PM
AuroraGirl's Avatar
AuroraGirl
And
a three way converter in place of the two cats would allow removal of the air pump and maintain the function of the air pump's purpose
95fiveoh
Dec 14, 2017 06:42 PM
gman97005
Nov 21, 2013 03:11 PM
broketruckjohn
Aug 31, 2013 01:02 PM
nacoa
Mar 2, 2004 05:37 PM
GammaDriver
Oct 20, 2002 01:19 AM
