Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Power steering upgrade
Old Aug 24, 2025 | 10:51 PM
mercon2's Avatar
mercon2
4wd High
1965 N700 330HD. What's stopping me from adapting a later Model PS gear box? Mounting: I can fabricate. Clocking to steering shaft: able to change to aftermarket shaft. Direction of rotation: Potential Problem. Donor truck: 1990's ford 700+, Freightliner 1990''s-2000's (or another)???
Old Aug 24, 2025 | 11:46 PM
The Extractor's Avatar
The Extractor
Does the behind the axle vs in front of the axle mounting change the rotation? Get the most common and easily serviced / replaced part you can find.
Old Aug 25, 2025 | 11:41 PM
mercon2's Avatar
mercon2
4wd High
The placement would effect it, I would assume. I've found some that are similar to my manual box
Old Aug 25, 2025 | 11:54 PM
The Extractor
I am selling my 1969 f600 with a 330 and power steering. I also have a power steering pump setup from a B600 bus with a 361-391 , possibly a 330. I will have to check which engine it is.
Old Aug 28, 2025 | 10:39 AM
asavage's Avatar
asavage
FTE Community Team
The F600's steering box is inside the frame rail (and hard to R&R: the engine/trans have to be moved to the passenger side in order to gain enough clearance); the F700's is outside the frame rail. IDK about the N700's.
Old Aug 28, 2025 | 01:08 PM
The Extractor
Oooh yes , that is the detail was sticking in my head that I couldn't remember.
Old Nov 13, 2025 | 11:34 AM
mercon2's Avatar
mercon2
4wd High
I bought a PS gear box from an 89 GMC 7000 with a 9k lbs front axle. Position is the same and angle is +/-10 degree. I plan to use the new pitman arm. I might have to mill a sleeve for the far end of the arm.
bald59
Oct 25, 2022 08:29 AM
f1fappys
Jun 19, 2020 11:41 AM
tjs-81
Dec 2, 2013 06:19 PM
thuletiger
Feb 15, 2005 05:03 AM
bodysaffa
Apr 4, 2002 11:15 AM
