(HELP) Code: U0146 - Lost Communication with Serial Data Gateway Module 'A'
Can someone please help me. I have a check engine light on due to a code U0146 - Lost Communication with Serial Data Gateway Module 'A'.
This happened when I changed the tire size on my F450 through Forscan. The tire size I switched to was 2641mm which is a confirmed valve as per the tire calculator. I completed a relearn of PCM, TCM and AWD modules and tired to clear codes multiple times with no luck.
Have you tried putting the original values back in to see if that clears it? When I did mine I didn't do a relearn of the AWD module... but I see in your sig that you have a 25. Have these changes been confirmed for the 25MY's?
