Need help locating Part!
Old Aug 24, 2025 | 10:49 AM
F100Michael's Avatar
F100Michael
3rd Gear
Question Need help locating Part!
Hey everyone,
I’ve got a 1976 F100, 5.9L automatic with what I believe is the factory air conditioning. I’m in the process of bringing the truck back to life and sorting through everything, but I’ve run into an issue trying to track down a specific part.
It looks like it’s part of the idler pulley assembly,
Unsure, part in question.
The bearing that runs with the belt off the AC. The problem is, I cannot seem to locate the exact replacement. I’ve already tried four different bearings and three types of pulleys, but none of them fit correctly or line up where the belt needs to run.
I’ve attached a photo of the part in question. It’s possible I’m off base and this isn’t actually what I think it is, but either way I’ve hit a wall.
Has anyone here dealt with this before? Do you know the correct part number or a reliable source that carries the proper replacement? Any guidance or suggestions would be greatly appreciated.
Thanks in advance!
Old Aug 24, 2025 | 01:39 PM
dlburch's Avatar
dlburch
what do the AC controls look like inside the cab? It could be a factory system or dealer add-on system....
Old Aug 24, 2025 | 02:36 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 that does not look like OEM idler bracket #8678
Old Aug 24, 2025 | 02:58 PM
F100Michael
3rd Gear
Old Aug 24, 2025 | 03:00 PM
F100Michael
3rd Gear
The brighter grey colored circle is where the part was at, I have since taken it out to go look around some junk yards and parts stores. Previous owner did quite a few janky things to it.
Old Aug 24, 2025 | 03:21 PM
77&79F250's Avatar
77&79F250
Dealer/aftermarket installed a/c system.
Old Aug 24, 2025 | 05:56 PM
dlburch's Avatar
dlburch
I've got one but the bearing is shot. Based on measuring mine and cross-referencing the part number D0AZ-8679-A (see last section below), I think this idler pulley will work. the diameter and the bolt size line up...
https://www.rockauto.com/en/moreinfo...t=6956&jsn=458
you should also be able to take the bolt out of your bracket and find an idler pulley at your favorite parts house...mine is just a hair over 3 1/2"
lewisriverkid
May 21, 2024 12:03 AM
PSDLOVER
27
Feb 26, 2024 06:46 AM
AuroraGirl
Aug 30, 2021 09:50 AM
coores14
Apr 29, 2009 04:08 PM
Snoopy1
May 7, 2004 08:55 AM
