Running board install
Old Aug 23, 2025 | 05:36 PM
8pack's Avatar
8pack
I went to put my drivers side running board on. I can't figure out how to mount it without dropping the mounting brackets and those are attached to the gas tank except the rear one.
Any tips?
I can add pictures tomorrow if it will help illustrate the issue.
Thanks!
Old Aug 23, 2025 | 06:37 PM
abe's Avatar
abe
You shouldn't have to remove the brackets to put the running boards on. If you take them off then you have nothing to mount the running boards onto. They sit on top of the brackets then are bolted in and bolted to front and rear fenders.
Old Aug 23, 2025 | 06:39 PM
avf100's Avatar
avf100
I just removed and replaced my LH running board on my f100, and you don't have to remove the brackets.
I started at an angle with the front end high and slid the running board to the back fender first and then lowered the front into place.
Kinda hard to see from this pic.
the f250 has 3 mounting brackets as the f100 only has 2, so it might be harder to do.
Maybe remove the rear brackets if necessary?
Old Aug 23, 2025 | 06:47 PM
8pack's Avatar
8pack
Thanks. Will try that tomorrow.
Old Aug 25, 2025 | 09:29 PM
8pack's Avatar
8pack
I was able to get the running board mounted but had to remove the rear support bracket to allow it to tip back enough far enough to move it into place.
I will post a pic when I do the passenger side.
4Kids
Apr 28, 2025 07:55 PM
Pappys53
Mar 11, 2023 10:05 AM
Tlta29
Jan 9, 2022 12:13 PM
CdnWillyG
37
Apr 12, 2015 03:29 PM
domdel63
Mar 29, 2010 09:18 PM
