Has anyone replumbed the fuel lines on a dual tank OBS with AN lines and fittings ?(mine is a 1993 F350 7.5 gas)
Would like to keep quick disconnects for stock filter and pumps.
thanks,
GP
I’m sure you could. I had to make a PTFE pressure hose from the DFR to the fuel rail on my ‘89. If your hoses are brittle and falling apart, another option is to buy new nylon hoses from Bronco Graveyard.
I have the lines with the plastic retaining clips at the fuel
filter and spring lock connections at the fuel rail. You should be able to find what you need.
thanks,
GP
Why not replumb with what stock is/was?
Why do you want AN fittings?
