Odd transmission shift
Old Aug 15, 2025 | 06:57 PM
silky_warrior's Avatar
silky_warrior
4th Gear
I have a 2021 ford f250 with the 7.3 in it and have never liked the transmission in it after hard shifts and everything in between. Well today I was at a stop sign and I went to take off and the truck was barely moving and I look down at the gear selector and it was showing I was still in 10th gear at basically a crawl and then it shot down to the correct gear. Has anyone experienced this? Should I head to the dealership? 77k on the truck
Old Aug 16, 2025 | 07:50 AM
OBS460's Avatar
OBS460
If it were my truck I would at least do an adaptive relearn on the TCM and empty the pan fluid and change the filter at 77k miles.
Old Aug 16, 2025 | 10:30 AM
silky_warrior
4th Gear
does this have to be done at dealer? I thought it was a sealed transmission and not really recommended to do fluid changes on them. New to the trucks so I could be wrong
Old Aug 16, 2025 | 03:45 PM
OBS460's Avatar
OBS460
I don't know for sure if the dealer HAS to be the one to initiate the adaptive relearn or if just unhooking that batteries for 30 minutes will work. The transmission is not sealed and they do recommend changing fluid at 150k miles. They are also in the parts selling business so they want to sell you parts when yours fail. It absolutely will not hurt to change the fluid and filter sooner than 150k miles.
Old Aug 17, 2025 | 08:54 AM
silky_warrior
4th Gear
gotcha, thanks for the reply and info!
bookieman
2009 - 2014 F150
Jun 20, 2025 06:58 AM
VanGo3
Oct 2, 2024 04:08 AM
mzuern
Jun 6, 2022 12:32 PM
Nomeo55
May 10, 2021 06:08 PM
joshsombo
Feb 14, 2006 12:32 AM
