Locked gear selector
Old Jun 13, 2025 | 04:18 PM
bookieman's Avatar
bookieman
2nd Gear
After draining n refilling transmission I cannot shift out of park
Old Jun 16, 2025 | 11:40 AM
2jhanna's Avatar
2jhanna
Did you drop the pan, maybe knocked something loose.
Old Jun 16, 2025 | 04:28 PM
bookieman's Avatar
bookieman
2nd Gear
Transmission alignment
Put together and wasn’t lined up properly. 1/8” off works great now
Old Jun 20, 2025 | 06:58 AM
2jhanna's Avatar
2jhanna
Originally Posted by brysondrive
Check the brake light switch if it’s faulty or disconnected, the shift interlock won’t release. Also double check any wiring or connectors near the shifter that might’ve been bumped during the trans service
byson, if you read post #3 above, the OP already found his problem to have been alignment related, and works great now.
VanGo3
Oct 2, 2024 04:08 AM
Nomeo55
May 10, 2021 06:08 PM
joshsombo
Feb 14, 2006 12:32 AM
