Sponsored by: Real Truck
Trailer plug constant 12v
Old Aug 13, 2025 | 08:51 AM
Carya's Avatar
Carya
4wd Low
Hey everyone. Thanks for stopping by.
2016 F350 DRW XL
issue I'm having is in the truck trailer wiring harness somewhere I believe?. The left turn light is getting constant 12v even when the truck is off and the right blinker does not blink, running lights power on fine, trailer brakes activate fine truck acknowledges the trailer.
all fuses appear to be fine, trucks lights do not exhibit the same symptoms however it does blink fast on the left side. But as far as I know these circuits are separate and the trailer is ran through it's one fuses and the TCM?
Any guidance is greatly appreciated. Thank you.
Old Aug 13, 2025 | 10:17 AM
Eman85's Avatar
Eman85
Unplug the trailer connector harness
Old Aug 13, 2025 | 10:54 AM
Carya's Avatar
Carya
4wd Low
I have pulled it at the back of the truck between the harness and the 7pin to test. Where else can I disconnect the trailer wiring harness?
Old Aug 13, 2025 | 04:42 PM
Carya's Avatar
Carya
4wd Low
Just an update got to the trailer control module. Pulled the connector and checked the pin on the module pin 1 on connector c2496c yellow wire cat06 that's showing a constant 12v.
so I'm guessing my TCM is in need of replacement? It seems to pull its power from fuse 10 and fuse 90 in the battery junction box.
Old Aug 22, 2025 | 01:13 PM
Carya's Avatar
Carya
4wd Low
Final Update / Resolution
Truck: 2016 F-350 6.2L DRW
Problem: Left trailer turn signal had constant 12v. When using the left signal, the right flasher would blink. (Side note: also had an 800mA draw on the maxi fuse link.)
Diagnostics Performed:
  • Tested trailer plug and connector.
  • Cleaned and scrubbed all connectors.
  • Repaired a wire that was rubbed halfway through at a plug under the steering wheel.
  • Verified grounds, continuity, and all fuses.
  • Pulled the connector at the trailer control module (TCM) and found constant 12v coming from it.
  • Checked everything between the TCM, BCM, and data wires.
  • Opened the TCM, cleaned out dust/dirt, but issue remained.
Fix:
Replaced the Trailer Control Module with a new unit. Problem solved.
Bonus: This also fixed an odd blink issue I was having with the truck’s normal flashers, even though trailer and truck flashers are on separate circuits.
heres some of the wiring I used to diagnose
Critter015
All Things Towing
Dec 8, 2023 11:47 AM
jonrjen
Electrical Systems/Wiring
Feb 17, 2015 03:55 PM
Trek93023
Sep 22, 2006 04:58 PM
KZooDirt
2004 - 2008 F150
Aug 15, 2006 09:00 PM
bluemoose89
Dec 25, 2003 08:07 AM
