My running lights are the only things that work when i hook up to my four prong adapter on my 1998 f150. I recently had blinker trouble so i sent my truck to Ford and they changed out the multi function switch. For about 2 weeks after that my lights worked. now i hookup to a different trailer and they dont work...not even on the trailer i normally pull. The different trailer does not have a short because it worked on both GMC trucks we have. I love my Ford but the lights are givin me fits...if anyone can give me some insight that would be great. thanks!
ok i have a 2005 f150 with pre wire for trailer towing i hook up my 1993 travel trailer to it and i have problems, my trailer works on three different vehicles but not mine. when i hook up the 7 wire and turn on the headlites nothing happens when i turn on my right sig lite all lites blink(running lites and all)left sig left trailer works the battery charger seems to work also,
...Welcome to Ford Truck Enthusiasts!
This is a very old thread...however, Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I would say your travel trailer and the three different vehicles are not wired right.
Here is some diagrams that will help you:
thanks for the information but would it be better to rewire the truck or the trailer ??? i understand that the ford has an odd wiring setup so would redoing the plug in the rear screw it up
I personally would wire the truck so it worked with everything as standard. If you ever want to borrow a trailer, it would be nice if it was plug and play.
I just installed a 7 point connector to my 97 F150 only to find the parking lights don't work. Everything else seems to be ok. When I tested the brown wire on the truck with a multimeter, nothing happened. My truck tail lights work fine. Any suggestions?
Thanks
Matt
when i had my problem i found two things one one of the tail lights was the wrong one it was a single post and not a two post. second in the fuse box you need to check the fuse and you also need a relay that does nor come supplied with your truck but you can find where it goes by the fuse layout, it should be for ttrailer running lights etc
If you have a factory towing package, and use the factory trailer wiring, then yes you have a seperate fuse and relay up front.
If you use the brown wire that is going to the license plate lights and the taillights on the truck now, then you should have no problems. I do not understand if your truck lights are working, the brown wire for the truck's taillights should be hot when the headlights are on. Make sure you find a good ground when you are testing the system.
