Taillight wiring issues
Old Aug 10, 2025 | 03:47 PM
Ian Jensen's Avatar
Ian Jensen
4th Gear
My passenger side rear tail light does nothing with a right signal or brake but is fully bright when the lights are on.
I just inherited this truck so I know nothing about the wiring but the bulbs have all been replaced with LEDs if that makes a difference.
If anyone has any ideas where to start looking it would be super appreciated.
Old Aug 10, 2025 | 04:48 PM
1TonBasecamp's Avatar
1TonBasecamp
LEDs can be polarity sensitive. If it’s a standard bulb base, try flipping it around. Although if it’s keyed, then that might not be possible. Check to make sure both housings are well grounded, however. Or yours, the standard style with a metal bucket and a plastic lens? Or are the LEDs complete modules?
Old Aug 10, 2025 | 06:00 PM
Ian Jensen's Avatar
Ian Jensen
4th Gear
Thanks for the help.
I had thought about the polarity issue but my understanding was that LEDs won't do anything if they are wired backwards. These do light up when the lights are on but they are bright, like if the brakes were pressed.
They are keyed bulbs so I am going to get some regular bulbs to test with.
I have the metal buckets that ground to the body.
Ian
Old Aug 11, 2025 | 08:54 AM
bszern's Avatar
bszern
Ian
Incandescent brake lights are dual filament, is the LED you bought comparable? It may have the same base for installation but might not have the same internal circuitry. Something to look at before you get into the wiring!
Old Aug 11, 2025 | 09:27 PM
Ian Jensen's Avatar
Ian Jensen
4th Gear
I would love for that to be the case but these LEDs work perfectly on the driver's side. I even tried swapping them over but still no luck on the passenger side.
I'm going to buy some incandescents just to test with. I am hoping that it has something to do with the polarity, but I do know that this wiring has been messed with so I am not getting my hopes up.
Old Aug 12, 2025 | 07:33 AM
bszern's Avatar
bszern
Gotcha, didn't realize that the driver's side was OK. Here is the wiring diagram for the back side. You could just re-wire the passenger side as detailed here, the passenger is just linked from the driver's side. Also check for functioning grounds on that side, it could be something easy like that.
https://www.fordification.com/tech/wiring/68-23.jpg
Old Aug 12, 2025 | 11:35 AM
blue68f100's Avatar
blue68f100
Remember that the tail/turn signal lights go through the switch in the column. These go bad over time.
Raymond Tomlinson
Dec 10, 2014 03:59 PM
wtx66f100
Oct 20, 2014 12:46 PM
Myfreeford
Nov 30, 2010 06:02 PM
Leesa682002
Mar 28, 2007 06:12 AM
Mil1ion
Electrical Systems/Wiring
Sep 15, 2002 11:48 AM
