need help wiring issue
Old Dec 9, 2014 | 08:17 PM
Raymond Tomlinson's Avatar
Raymond Tomlinson
Have a 79 f150 and when the brakes are in use the front driver side turn signal comes on as a brake light can anyone help me please its kicking my butt trying to find out why all other lights work right but that on
Old Dec 9, 2014 | 08:42 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Wow that is a new one....something is crossed up in your brake and turning signal wiring for sure. Maybe these will help?
Old Dec 9, 2014 | 08:52 PM
HIO Silver's Avatar
HIO Silver
Have you reviewed the wiring diagram... lately?
http://www.fordification.net/tech/im...aster_5of9.jpg
Tell us what those two circuits have in common. Meaning, the front parking lights are receiving a voltage when they are not supposed to.
Drum roll please.....
Old Dec 10, 2014 | 01:19 AM
Raymond Tomlinson
wiring issues
I have the factory wiring digrams from ford and its not helping me any I have so many wires that have been cut found two wires that are not in the digram that are cut in half I am lost this is what I am good at about to say the hell with it and rewire the whole truck justed because of that one light the light has to be crossed or shorting out or tied in to the brake switch
Old Dec 10, 2014 | 05:04 AM
77&79F250's Avatar
77&79F250
So wires have been cut, ok no problem find the ones that have been sliced back together wrong. Meaning just go look for just that splice, by the PO probably.
Old Dec 10, 2014 | 07:53 AM
dlburch's Avatar
dlburch
Check the simple things first. Confirm the rear bulbs are good and correct for the application. Second check the condition of the sockets (no corrosion). Next check the resistance from the sockets to ground. Does the front light still come on if you try it with both rear bulbs removed? If so you prob have a wiring or turn signal switch problem
Old Dec 10, 2014 | 08:14 AM
HIO Silver's Avatar
HIO Silver
Well Raymond, that would have been important information to include in your original post. Then we may not have bombarded this thread with wiring diagrams.
Old Dec 10, 2014 | 03:59 PM
Raymond Tomlinson
wiring issues
If I know that the wires was cut I would have but I also checked the wiring the two that I found cut are cut at both ends and the only places that cut and put back together was spots I cut and moved away from the header and I did one wire at a time but all back lights work right and the front works right with out the brakes applyed and all still work but the drive side front trun signal comes as a brake light
wtx66f100
Oct 20, 2014 12:46 PM
1976HighBoy
Nov 10, 2010 09:52 AM
papertiger00
Dec 31, 2007 01:34 AM
thecowboy
Electrical Systems/Wiring
Aug 19, 2005 04:42 PM
frenchf250
1997 - 2003 F150
Aug 8, 2004 07:16 AM
