Crank, no start. please help
In the beginning, the battery light came along with a slow crank to intermittent no start. I had the battery and alternator checked out, all good. I replaced the starter, thinking that was it. Now, it just cranks fine but no start. Neither of the fuel pumps are turning on when I turn the key.
The fuses and relays have all checked out, the inertia switch is pressed down, I've bypassed the electrical by jumping from the battery to the fuel switch. I can hear both of the fuel pumps turn on this way, but I have zero pressure with a gauge at the fuel line. I'm not sure if this would be a fuel pump problem or not.
I went ahead and replaced the switch since I was there. I'm getting ready to replace the fuel filter and the fuel pressure regulator as a shot in the dark. I have no idea on what else to do. Any input would be greatly appreciated.
Do you have fuel pressure at the rail? Probably not, is the pumps are not coming on at all. Remember, they will only run for a few seconds when you turn the key to the start position, you do not have to go to the crank position.
As for the no spark:
You say you tested the Coil with no resistance? Does kind of sound like the coil, but go through this Guide, It is long, but it will get you the answers you need.
https://easyautodiagnostics.com/ford...n-module-tests
If you have both no spark and no fuel, My money is on the ecu.
I pulled the ECU and nothing really looks abnormal. If I have to go this route, where would I get one from that would be reliable?
So, lets get the fuel flowing before we mess with anything else. When you pulled the ECU, did you open it up? Pictures by chance? often times the Capacitors will leak and cause problems you can't see from the outside.
Depending on your skill set, you can get a set of replacement capacitors and solder them in. If that is not something you are comfortable with, you will need the code off the ECU. There are several numbers, take a photo of the connector and post it so we can get you the right one.
That glob of silicone on the #1 wire is a concern. That is the power that supplies voltage to the keep alive memory (used to help with fueling)
Anyway, open that puppy uppy.
Here it is
What you need to do is get another ECU with the F5TF-12a650-ALA and or DOE0
Now, there may be some that are really close to those that may work, but if you can find an exact match, that would be best. Another option is to send this one off and have it rebuilt.
Should not be that expensive.
Get this sorted, and then on to the next step.
i just picked one up, remanufactured, caps replaced, but doesn’t get second gear in drive.
so, even if your caps are replaced, there could be other problems with the ecu.
